  New Posts New Posts RSS Feed - Engine Issue...
Engine Issue...
thyeag1982 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thyeag1982 Quote  Post ReplyReply Direct Link To This Post Topic: Engine Issue...
    Posted: August-11-2020 at 11:15am
Has anyone experienced starting the engine and the only way it will stay running is you holding the ignition key in the start position.
As soon as I let the key go the engine shuts off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 11:33am
Jeff,
Get the VOM (volt Ohm meter) out and see if you are getting the nominal 12 volts on the R terminal at the ignition switch with the key turned in the run position. Report back with what you find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thyeag1982 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 1:57pm
Yes, we're getting 12 volts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 1:59pm
Normally means the key switch has worn out but Pete is telling you how to verify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 2:00pm
Check if the coil is getting the 12. If not, then check any connections between the coil and the switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thyeag1982 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 2:47pm
Thanks for the responses!.
I'll let you know what we find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 3:03pm
CORRECTION:
There should be a ballast resistor before the coil so you should see 12 volts in and about 9 volts out to the coil.
Hysteria View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hysteria Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 4:20pm
Some boats have the ballast resistor wired into the run circuit only and bypass them when cranking. You didn't mention what you are working on, but a bad ballast resistor in that type of design will do exactly what you are describing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 4:36pm
Unless modifications have been made or the boat repowered, there is no resistor bypass during cranking on his engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hysteria Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 4:44pm
I didn't see anywhere that he listed what boat he is working on
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2020 at 5:08pm
Sorry. You are correct.I just assumed he was working on a CC. We'll need to see what he comes up with.
3mile View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3mile Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2020 at 7:09am
Did u replace the ignition switch? Last time I replaced mine I had the wires wrong and this is what happened
