  New Posts New Posts RSS Feed - autolite 24’s?
autolite 24’s?
bsucics View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsucics Quote  Post ReplyReply Direct Link To This Post Topic: autolite 24’s?
    Posted: March-17-2007 at 4:24pm
Switching to autolites for an '89 2001 351. Which are the correct plugs? Searching the forums, looks like 24 or 25? What is the difference and which should I be using? Thanks!
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2007 at 5:34pm
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsucics Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2007 at 8:49pm
Tim - what's the difference - why would you choose one over the other? Not sure what you mean by a hot plug. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2007 at 9:53pm
A spark plug is said to be "hot" if it is a better heat insulator, keeping more heat in the tip of the spark plug. A spark plug is said to be "cold" if it can conduct more heat out of the spark plug tip and lower the tip's temperature. Whether a spark plug is "hot" or "cold" is known as the heat range of the spark plug. The heat range of a spark plug is typically specified as a number, with some manufacturers using ascending numbers for hotter plugs and others doing the opposite, using descending numbers for hotter plugs.
The heat range of a spark plug (i.e. in scientific terms its thermal conductivity characteristics) is affected by the construction of the spark plug: the types of materials used, the length of insulator and the surface area of the plug exposed within the combustion chamber. For normal use, the selection of a spark plug heat range is a balance between keeping the tip hot enough at idle to prevent fouling and cold enough at maximum power to prevent pre-ignition leading to engine knocking. By examining "hotter" and "cooler" spark plugs of the same manufacturer side by side, the principle involved can be very clearly seen; the cooler plugs have more substantial ceramic insulators filling the gap between the center electrode and the shell, effectively carrying off the heat, while the hotter plugs have less ceramic material, so that the tip is more isolated from the body of the plug and retains heat better.
Heat from the combustion chamber escapes through the exhaust gases, the side walls of the cylinder and the spark plug itself. The heat range of a spark plug has only a minute effect on combustion chamber and overall engine temperature. A cold plug will not materially cool down an engine's running temperature. (Too hot of a plug may, however, indirectly lead to a runaway pre-ignition condition that can increase engine temperature.) Rather, the main effect of a "hot" or "cold" plug is to affect the temperature of the tip of the spark plug.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsucics Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2007 at 10:34pm
Thanks - I appreciate the details. So from your explanation, it's correct to say that 24, 25, or 26 is an acceptable plug for my engine (26 being hot, 24 being cold)? The determining factor would be the performance noted on your boat - fouled plugs or knocking?
Also, this will be my first spring with my boat. I assume that fogging the engine last fall fouled the plugs? Should I run the engine for a while this spring with the old plugs, before swapping them out?
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2007 at 7:37am
wouldnt hurt anything to do it that way....id go with the 25's..
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2007 at 8:03am
Out of four available heat ranges, 25's are second hottest; not best for marine loading.
May I suggest stick with the 24's.
If you think your tub deserves something better, consider AR24's; They are nickel plated so the shell holds up beter in the marine environment.
If you are totally type-A and it make you feel better paying ludicrous money for spark plugs AP24, or XP24's, or APP24's or ATI24's but you won't net any performance.
River Rat to Mole
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 6:21pm
Gottaski, if you buy autolite app24's they are warrantied for life buy one time replace when burned up for free. No questions asked.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 6:37pm
what do they cost per plug???...full life time replacement??...gotta be a catch..
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 7:06pm
Theyre double platinum... not cheap. $5 or 6 a piece (at least).
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 7:14pm
wow....whats the point of them, your not gaining any hp correct?..triple the price of a reg. set.. iguess if theres no strings attatched with the warranty then its kinda justafiable..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 8:18pm
never had a problem exchanging them for new ones. I think I pay $2.50 a plug, yeah that sounds right off the top of my head. Just under $22 for 8 of them. I get garage discount though, not sure what list price is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 9:11pm
hmmm, thats almost retail for the std 24's.
River Rat to Mole
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 9:16pm
yea that seems like a huge backdoor discount, i mean garage door!!........standard plus are just under 20 for 8 of them
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 6:18pm
Some of the mark ups on parts for cars are crazy. It would blow your mind to know what the parts stores really pay for some of our parts verse what they charge the public.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 6:20pm
I think the regular 24's I pay just over a buck a piece for them. The regulars are not marked up as high. I don't usually get them unless they are going in something I am selling.
