  New Posts New Posts RSS Feed - starter question
starter question
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Topic: starter question
    Posted: October-09-2020 at 10:37pm
Take a listen to my starter.  Seems to work ok, just makes that funny extra sound.  I say it works ok.  As a rule, it does, but last night it struggled a bit to start and that noise persisted a little longer.  Today (day of this recording) it was better.  Any idea what is ailing it?  If its a quick open and lube or whatever, I will take it on.  Otherwise, I will try to track down a rebuild shop (my old guy that used to do it in his back yard shop retired....I guess he was about due, he was about a hundred.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 1:10am
That is a bad sound, I listened several times and can't identify the sound.   Maybe bushings in the starter but I have to say I have heard bad starters before but not that sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 5:21am
Larry,
I agree with Mark. I too can't identify what's going on but it doesn't sound good. I don't feel a lubrication will cure it. The starter needs to come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 9:29am
Sounds like a dry nose bushing to me,pull it and check. If you decide to take it to someone google prices first you can get a US made Arco 70200 very reasonable. DB is cheaper but they are Chinese. Should be real easy to get out these modern starters are way lighter than the old one on your Skier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 9:41am
I was going to say the same. Not sure what the difference is between the 70200 and 70125 (starter vs kit maybe?) but I know I couldn’t get a starter rebuilt for the $120 they’re selling for, at least not around here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 10:04am
Thanks for the nudge in the right direction. I already started looking into Arcos.  Hadnt dug out this handy dandy diagram I rely on yet to see which one I needed.
That CCW CW notation they use always confuses me.  Gary and Tim, your guidance helped.  Tim,  Where did you find $120.  I didnt see anything quite that low, I think I found in the vicinity of 160-190, but at that point wasnt sure which one I needed.  I concur that at those prices, new makes more sense than rebuild.
Now getting it off.  Heaven forbid all boats be like my Tique with the top mounted starter.  I tried getting this one off a while back to inspect it and it didnt go smoothly.  Full confession, Im not sure if this starter got wet or not. In a bad storm a while back, water got up to the floorboards.  Would that have submerged the starter.  Thats when I tried to take it off, inspect and dry out if needed, but I could never get it off.  Could that have led to this current condition?  It was a couple months ago and this noise just started a few weeks ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 10:13am
Yes it could have Larry. Couple of years ago I flooded my starter with saltwater and since we were going on the 3 day river run I just went out and bought the Arco. At the time I just googled and found one for something like 130. I'd bet you can lube it and save it for now though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 10:20am
I think your right on the kit Tim - and all that is is an extra 14? gauge wire with ends on it. If I recall it's when you have the old Ford starter and convert over to these newer ones. Larry will already have that wire. I think that blower in your way Larry is giving you a harder time getting it out. Can you remove it easy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 10:27am
Just from the google:
https://marinepartssource.com/ford-302-351-starter-arco-70200?utm_source=google_shopping
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 11:17am
ordered.  Here wed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2020 at 7:33pm
Larry, have I got a deal for you Wink
Since you have a new starter coming, after you get it installed and all is good, how'd you like to ship me the old starter and I'll take it apart and lay all the pieces out next to a disassembled automotive PMGR Ford starter for comparison purposes with plenty of pictures so the difference in the auto vs marine versions of this starter can be seen.
People might be surprised Wink
I'll even pay the shipping cost both ways and I'll do a Pete style "fluff and buff" on it.....not a rebuild.  Unless there are bigger problems to resolve.
Let me know what you think
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2020 at 8:37pm
Sure Ken, we can do that.  I have to admit, for me, I pretty much jumped the gun on this one, ordering new, before taking old off and exploring/trouble shooting a little on my own, but I figured with that noise, it can be good, and as Gary and Tim suggested, price of new isnt much more than rebuild, even if I could find a local rebuild.  So, I went for it.  I should even have just the right box to send it off in after the other arrives later this week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2020 at 7:15am
Sounds like a plan Larry  Wink
I sent an e mail to your Yahoo account with my address.
I would have had the same recommendation as Gary and Tim about a new Arco starter.
After you have the new part, it's a lot easier to dig into the old, knowing your boating time won't be affected if the fix gets long.
And besides if it's an easy fix, you'll have a spare starter............and spare parts are always handy.
Somehow I think Gary would agree with that Wink.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2020 at 1:35pm
Well, Larry's starter showed up, so I took it apart and since I like taking things apart, I also took apart a cheap Chinese starter for comparison purposes
The Chinese starter was sold as an automotive starter, Larry's was the original equipment starter in his SN176
Now it's time to look at the pictures and find the one extra part in the Marine starter. It's kinda like playing "Where's Waldo" Wink
It should be pretty easy to spot that little Brownish Orange seal/plug.
That's the only difference in the two starters as far as spark protection goes. It plugs a space at the bottom of the starter where fumes could get in and mix with a spark and make bad things happen.
The upper plug is black on the Ford and white on this particular Chinese starter.
There are some other differences like paint, Larry's has a black epoxy paint ( a pretty sloppy one) on the housing, the Chinese looks to be a pretty corrosion resistant non painted housing.
Larry's has tinned wire from the brush holder to the solenoid, the Chinese has untinned copper
I've had Arco starters apart, they have the same plug as the Ford, just a different color.
I've also had marine starters from other outfits apart (both new and rebuilt) that either has nothing at all where that plug goes or an application of RTV in that space but they were sold as "marine starters"
That little 10 cent or so piece of nylon sure adds a lot to the price of a "marine" starter
l
Larry's starter was full of rust, dirt and carbon dust all mixed together, not because he got it wet a little while ago, but from 20 plus years of use.
Also there was not a hint of lubrication on the nose cone bushing or the cover bushing on the brush end or any of the planetary gears. 20 plus years wiped all that out
Since I like to put things back together too, I fluffed and buffed Larry's starter, then put it back together with some grease in all the right places.
And then, since I like to see if things work again, I did a bench test and it worked good with no load on the bench..
But since I like to see if it works on an engine too, I slapped it on the old plow truck and it worked like it should.
It'll probably be Monday before I get it shipped out and on it's way back to you Larry.Wink
Now you have a good spare "just in case"
And just a reminder, this post only pertains to  Ford PMGR starters
