  New Posts New Posts RSS Feed - How Did This Happen??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Topic: How Did This Happen??
    Posted: November-12-2020 at 1:08pm
Now that's a clean bilge!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2020 at 10:00am
NICE. Good time to grease the rudder!
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2020 at 9:02am
all repaired now. guy did a great job and the damage was $500 which seems very fair to me. If anyone needs fiberglass repair in NE Michigan, D&D in Black River is the way to go...Don's the man...
zwoobah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2020 at 10:34pm
I’ve also got a Hewitt cantilever lift. Works fine, but in low water I managed to scrape the hull on the bunk while backing off the lift. The corners of the bunks are certainly sharp enough to damage fiberglass. I think your theory is correct. If you’re gonna have it on a lift, the lift needs to be raised until the boat is solidly planted on the bunks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 3:15pm
Ahhh, ok, that makes some sense. I had a Hewitt CL lift and I’m sitting here trying to remember the layout....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 2:47pm
no, i think it's from the boat lift as i mentioned above. the "hole" lines up about with the end of the boat lift bunk which, with this lift, is like the corner of a 2 X 4...so it could generate a large point load under certain conditions (ballasted boat + waves). also, it wasn't really a hole...that photo is after i poked my finger in there. it looked to me like it had been repeatedly flexed in that area and the gel cracked away and the resin cracked allowing water in.  that seems like the most reasonable explanation to me, just wanted to see your all's ideas.  no shrapnel on the inside.
appreciate all the input!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 1:21pm
If you've definitively ruled out damage from the boat lift and damage resulting from a failure inside the hull, then my guess would be hit from a sledge. The hole appears very uniform. Was there shrapnel on the inside?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 12:08pm
I’ve seen boats on lift bunk brackets that barely made a scratch.
Something very strange here
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 8:56am
no "bunk flipping" possible with the lift...its a hewitt cantilever with "Al V-Bunks"
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 8:31am
One theory...
If your lift is like some lifts i've seen, I believe a bunk on the lift was loose and flipped over, can occur upon reversing, the boat was later raised,  the upright and hardware punched through when raising the boat.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 8:16am
Pete, that definitely occurred to me...i figure they would use a drill or hole saw...not hit it repeatedly with a hammer...besides, my wake causes far less damage than a day with 20 MPH wind...or the ice every winter...or a similar sized, unweighted boat plowing along at 10MPH, or a "tri-toon" with 20 people plowing along...etc, etc...
Tim, I don't have any other photos and the boat is 4 hours away awaiting repair. the damaged area (hole + cracks) is roughly 6" diameter, about 14" from the stern, and inline with the starboard side secondary stringer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2020 at 4:14am
Those close ups are interesting but I can’t make heads or tails of them without a little context (size and location). Can you take more pics from inside and outside zoomed out a bit?
DVskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 8:16pm
Good one Pete! Any boat with a tower is suspect!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 7:48pm
Did your stringer crack and pull-up the exterior hull into the bilge
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 7:47pm
Nick,
Maybe there's someone on your lake that isn't very happy with large wakes that are eroding the shoreline? Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 7:28pm
definitely didn't hit anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 5:57pm
Looks like you hit something to me.
Many years ago, on my 1st boat, the trailer bunks cracked the hull like you suspect, but they were long cracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 4:53pm
I had noticed an abnormal amount of water in the bilge since Labor Day...water up to the top of the bilge pump after wakeboarding for an hour. Didn't think too much of it and planned on removing the RR seat, back panel, etc. when I pulled it for the winter to investigate...figured airguide hose or exhaust or maybe even platform bolts. Needless to say I was pretty shocked when I pulled it out of the water and took a look underneath when it was on the trailer. Big question is what caused this? This boat lives up north on a lift so it gets used roughly every other weekend late april - early october. When it's being used it has ~1000lbs in ballast and the lift isn't all the way up so the boat is partially in the water. The hole is also roughly at the end of the boat lift bunk and right where the secondary stringer "cuts in" at the back of the boat. I figure boat lift bunk corner + ballast + boat bouncing from waves all summer or maybe just one big wave? what do you guys think? Luckily I found a guy fairly close (~45 minute drive) with 40 years experience repairing fiberglass who says "no big deal"...last photo is the boat at his shop...it was a nice day...
