1978 Fish Nautique |
leetudor
Groupie Joined: August-29-2014 Location: Mount Juliet,TN Status: Offline Points: 96 |
Posted: October-02-2020 at 5:31pm |
I just bought a Fish this week. I have looked at some photos of others and most have a different tower than mine, is mine a factory tower?
There is no such thing as a fish with a factory tower, they just weren't thought of yet. By the time they were fishes were extinct ;)
leetudor
Yeah, that is what I thought.
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2997 |
That’s no tower...it’s a trolling set-up. Fish gets on and you throttle up for a fishy tube ride.
leetudor
Does anyone have a picture of how the shift cable holder is mounted on the transmission side? This boat has nothing and the outer jacket is the only thing moving.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11170 |
Here's a link to a bracket kit, maybe you have some of the parts but not all from the sound of it Here's a picture that shows how it mounts |
leetudor
Thanks for the picture. I bought that retainer but on my Fish, the cable comes down the side of the bilge area loops around and comes from the rear of the boat. Most pictures I have seen on the web and in person on the PCM 351's show them coming across the intake manifold then down like you show.
rebel skier
Gold Member Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 777 |
Looks to be in the same place in some of the pics of this twin engine fish
leetudor
If I mount mine like that, the directions will be opposite. Forward would be reverse.
leetudor
Also where does the battery go? Mine was mounted in the livewell and I want that for storage not a battery.
Click on the link below for a Morse throttle/shift control manual It's for an MV-2, you could have an earlier MV-1 but the directions for changing the shifter action are basically the same thing. If you have some other control, then this is no help |
leetudor
I have an Ole School dual lever shifter. |
Well, I'm no help then
Good luck.
Here's a manual for a dual lever shifter that may or may not be the same as yours since you didn't say what yours is But ..........if you read it you can see that the shifter can be setup to push or pull with a little disassembly to get at things, then when you move the lever forward, the boat will go forward. Whatever make and model you have, it should have that capability. Once again.......good luck
leetudor
Thanks. I will look at mine closer and see if it is the same. Top side looks different but bottom side might be the same. Might take a brain surgeon to sypher it.
If it's like this they used those controls in a lot of boats. It will just need the cable attachment to the throttle bellcrank and it's clamp moved to the opposite side of the control....
Something like this- |
leetudor
Thanks, I will look better at it in the morning. If I go that route, I will need a new cable about 5 foot shorter.
leetudor
This is what it looks like.
leetudor
Does anyone know the battery location?
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1795 |
Have you tried following the battery cables from the starter to wherever they may go?
rebel skier
leetudor
Yes, Like I said above they go into the livewell and I do not want to put them back into that compartment.
rebel skier
It might be worth tryin to grab the pics in this old for sale add too:
The problem is if you create an account with pop yachts they will spam you for a good while.
rebel skier
I wouldn't be surprised if that live well batter was set up to be a house battery versus a starting battery.
leetudor
I thought about that area, will need to add a door to my floor panel for easier access.
leetudor
SO the stand off L bracket came in today. I am going to mount it and look into changing the throw action of the handle this weekend. I will for sure have to get a much shorter cable.
fanofccfan
My bad....did not read the entire thread.
Bill, I've done it may times too. Then the only problem is, it gives Ken another excuse to come after me with his criticism! |
You bet it does. You just ask for it. By the way, you misspelled "many"
