Trailer seals |
Author | |||||||
Kat Daddy
Newbie Joined: June-19-2018 Location: Columbiana, Al Status: Offline Points: 35 |
Posted: March-04-2021 at 9:27pm |
Does anyone know an inner wheel seal # for the 6 lug bfn trailers? It has the ez lube axle and etrailer cant cross reference it.
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1194 |
You might be able to use micrometer and measure innner and outer. That should narrow down
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 330 |
Thats what I had to do with my 98 SN trailer. This is what I ordered from E-trailer. 10-10 Grease or Oil Double-Lip Seals
That should work. Whatever comes in the standard 5200lb(bearing/hub) kit is what you need.
Kat Daddy
That measurement sounds about right, bought a digtal thing from harbor freight and was 2.13...close enough.
Mpost
Double check your OD. also. That 10-10 seal does not seem to come in any of the bearing kits. Had to order them seperatly.
