  New Posts New Posts RSS Feed - Trailer seals
Trailer seals
Kat Daddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kat Daddy Quote  Post ReplyReply Direct Link To This Post Topic: Trailer seals
    Posted: March-04-2021 at 9:27pm
Does anyone know an inner wheel seal # for the 6 lug bfn trailers? It has the ez lube axle and etrailer cant cross reference it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 3:53am
You might be able to use micrometer and measure innner and outer. That should narrow down
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 8:31am
Thats what I had to do with my 98 SN trailer. This is what I ordered from E-trailer.
10-10 Grease or Oil Double-Lip Seals
I.D.
O.D.
Use With:
2.1253.376E-Z Lube and Oil 5,200, 6,000 and 7,000 LB Axles
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 9:38am
That should work. Whatever comes in the standard 5200lb(bearing/hub) kit is what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kat Daddy Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 8:28pm
That measurement sounds about right, bought a digtal thing from harbor freight and was 2.13...close enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2021 at 8:57am
Double check your OD. also. That 10-10 seal does not seem to come in any of the bearing kits. Had to order them seperatly.
