Trailer hub grease fittings |
Author | |||
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1846 |
Posted: April-29-2021 at 1:57pm |
The small-ish fittings on my hubs will pop out when removing the press-on style of grease gun. Ok to over size the fitting?
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2979 |
How about installing a set of Bearing Buddy wheel bearing protectors? Some are nay-sayers on Bearing Buddy, but they've never let me down yet.
https://www.bearingbuddy.com/ JQ |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11116 |
I can't decide whether you're saying that the grease fitting pops out of it's threads or something else. If that's the case a grease fitting with bigger threads seems workable.
Drive in or as mentioned "press in" Zerk fitting will pop out. Threaded is certainly a better option but I'd say disassembly to keep metal drillings and tappings out of the grease is best. Using the old "grease on the tap" trick is too risky. Mark, Try a new drive in Zerk.
ultrarunner
Yeah, the Zerz is coming off with the gun. I'll get the next size up Zerk drive-in. That should do it.
Yeah, the Zerz is coming off with the gun. I'll get the next size up Zerk drive-in. That should do it. [/QUOTE]
The next size up requires drilling.
ultrarunner
Ahhh...ok. Well, I'm picking up the boat in the next week or so. I was going to change hubs, but I think I'll pull them off, inspect, replace what is needed, if anything, and put back. Easy enough to drill or tap for either a press or threaded Zerk, at that time.
