Stuffing box |
Slalom fan 4
Groupie Joined: May-09-2020 Location: Idaho Status: Offline Points: 73 |
Posted: May-07-2021 at 9:58pm |
I'm trying to replace my stuffing box packing on my 93 sport but that little stainlesd collar on the shaft just a few inches in front of the packing nut is in the way. It has two Allen head set screws one I can loosen and it frees up the collar a little but enough to slide it forward, the other screw won't budge. What is this for and how do I move it?
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3770 |
It keeps the shaft from slipping out the back should it come loose from the tranny.
If the set screws are not stripped soak them. PB blaster, Kroil are popular but a mix of 50/50 acetone and ATF, automatic transmission fluid works about the best. Soak the screws and give the mix time to soak in. Overnight at least. If that does not work you can always add heat but not to much if you plan to keep that shaft. Before spending to much time you can drill out the set screw and tap the collar to the next larger size or get a new collar. Last option use a cut off saw, dremmel or angle grinder with a fine blade and carefully cut the old collar but it should not get to that. Mark
That is a safety collar. If your shaft ever comes out of the coupling that collar prevents the shaft from sliding back and jamming into the rudder. If done at speed the prop jambs into the rudder and sometimes the strut gets torn off. After all that happens you then find water coming into the boat through that 1 inch hole and through where the strut once was. If you cannot get that set screw out with heat and lube you will have to cut it off. Split collars are available for replacement.
Slalom fan 4
Ok thanks much for the info.
UrSofaKingLucky
Newbie Joined: August-23-2020 Location: British Columbi Status: Offline Points: 3 |
Use heat and Candle wax. As a Machinist by trade, this is the one trick that ALWAYS works.
Heat up the collar until the wax melts, melt wax on the screw head, and just let the heat wick the wax into the threads, when it cools it should just turn right out. Old school, but amazingly effective.
88 Nautique 2001
