Trailer HUB FAILURE! |
Post Reply | Page <1234> |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3764 |
That is a very long distance to leave the boat behind, you are doing well to get this taken care of so quickly. The pucker factor must be huge.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11155 |
So how'd the boat and trailer get hauled the 60 or so miles from Warrenton to Louisa? It's been almost 4 hrs, it must be there Ya can't just leave this episode of the story unfinished
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1860 |
Ha Ken, good point...
So, BoatUS lined up Tommy's Towing, out of Culpepper, so they had some driving to get to the boat and then to Lake Ann. Insured and DOT'd, and they do heavy-duty stuff, so felt fine with them. They were sending a roll-off and were well briefed the wheel was off and to NOT leave it behind. As of an hour ago, dispatch said they were just about to Louisa. I'm expecting a call shortly verifying delivery. I'll hook up with the shop on the phone tomorrow after they've inspected the trailer, and we'll come up with a plan of action.... At a minimum, new axle, hub, brakes and bearings on the right side. Possibly a new drum and heat shield? I'll have them pull the left side apart and inspect. I'm guessing we'll do new brakes/actuator and a hub and whatever else needs attention on that side. Thoughts on bearing buddies? As you all know, I trailer a LOT, so don't mind spending the bucks to do it all right. Here's a post-fire pic after the smoke cleared and I dragged it to parking. The drum is still attached to the wheel. The brake shoes fell out when the wheel came off as I entered the parking lot, still smoking when I walked up to them... |
You dun did it now Mark
With that one picture, you're bound to generate at least 5 or 6 opinions on whether that spindle will be able to be reused
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5323 |
Damn it Ken ....ya beat me to it! That spindle will buff out. Just polish it up a bit and she'll be good as new! |
ultrarunner
Ha, no kidding guys. That spindle will wind up on the shelf with a few failed aircraft components I've collected over the years. A few of the latter left me stranded WAY further than a few hundred miles from home
Donald80SN
Speedy Sleeve !!!!!!!!
cotter pin is still good, you should be good to go!,
Wow, first time I have seen that failure. Your nut, cotter pin and lock are in place? The Seal is still in place but the bearing rollers are all gone? The hub is gone the brakes are gone?
My guess, yep I will go right out on the limb and take the heat. Your hub fractured, I can't see any other way the wheel can be gone and leave all those parts on your axle spindle. It looks like the inner bearing cones are still on your spindle. There is a chance you will pull the nut and pull off both bearing cones to find the spindle looking just fine IF the dragging on the ground did not grind all the way through the lower half of the bearing cones and damage that axle spindle. It very well might have but another positive, you don't show excessive heat on that spindle, no blueing. Your brake drum is also the hub on trailer hubs with brakes and it is bolted to the wheel. I am trying to wrap my mind around the failure fracturing the hub causing enough heat to light the grease on fire and still leaving the key axle components on the spindle looking pretty good. I suspect the hub fractured, maybe a hard pot hole hit, when the hub fractured the bearings started falling apart letting the brake drag on the drum, the heat that lit the fire was the brake dragging on the drum before the total failure happened. It does not even look like the seal burned up, it is still in place and seems to be in shape. Terrible failure on the road but it looks like you got off lucky on this one. Can you share a picture of the brake drum? That would be interesting to see. If I am all wet on this one I will take the punishment standing up.
Normally I stay out of these arguments, like the spindle discussion last week, but.................if there's punishment to be given out to MrMcD, this is just to juicy to resist
So I will boldly go out on the same limb as Mark and say that unless the spindle got bent or blued from excess heat, you won't need a new spindle or axle. Since the shop will be seeing it up close and personal, they should be able to give you a good answer. I'll take my punishment right next to him butt bent over with plenty of lube. Now should that lube be synthetic or natural |
Morfoot
As long as you're using the right oil with the proper amount of ZDDP you'll be okay!
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13520 |
Hell of a failure. Thanks for capturing that pic. It will be very interesting to see what’s still bolted to the wheel. Make sure they send you a picture!
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1792 |
I will agree with Mark and Ken but will not line up to take the severe punishment that is being discussed!
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1116 |
Looks the same as mine did. Once I removed what was left of the bearing the spindle looked OK. Installed new parts and got back on the road. There is still, 10 years later, a nice gouge in the road on the way back from our lake.
92 SN - Owned since 93
I agree with Desert and some of Keno.
Keno - if you didn’t destroy the bottom of the spindle grinding it along the ground you should be good. Agreed Bearings are two piece units once the cage separates. The outer piece of both the outside and inside bearing would have the clearance over the nut allowing the wheel to separate from the spindle leaving the inside race and the outer shell of the seal. Have seen it happen before. A good cold chisel and hammer can take the inner race off without much of a problem, so hold up on the puller rampage at harbor freight and just get a good cold chisel. Mark if you do get new spindles get these - https://youtu.be/nzKZ7hjExtk
Well will ya' look at all this discussion I started
We're all pretty much agreeing but none of you sissies are gonna take any "punishment" except me and MrMcD
I was thinking 30 lashes Ken, that is as far as I will go, your punishment is far more extreme.
If the wheel/hub came off over the nut washer and lock I would have to say the factory washer was too small or weak. No way a wheel should be able to come off with a proper nut, lock cotter pin and washer in place. I never saw that in automotive applications in 40 years. If that is how it came off that is a factory defective design at the trailer manufacturer. START A RECALL!!! Good luck with that most trailer manufacturers don't seem to be around long.
It’s not an automotive application and yes it can. If mark was with the trailer I would say go with it but since he’s miles/hours away he’s at the mercy of what the shop wants to sell/be liable for.
Ok start with the beating.
Curiosity made me blow up the photo of your failed wheel end. When blown up it looks like there is a gap between the washer and the bearing cone of maybe 1/4"? Those two should be touching. The washer pushed in by the nut holds your bearing adjustment. The cotter pin is still in place so the nut should not have moved.
With 1/4" of play that wheel would have had major wobble issues before the failure, you would have noticed tire movement/wobble.
The cage around the bearing rollers is just there to hold them in place for assembly. Once assembled the cage does nothing that affects bearing life. Some modern bearings have cages made of plastic today to save money and because there is no load on them. The bearing adjustment and the tracks in the bearing cone are what keeps the bearings in place while assembled. This one is an odd failure to figure out. |
I was talking about a colonoscopy, what ever did you guys think I meant
To late just had mine I feel so violated but at the same time cleansed.
Gun Driver I hope you are much smarter than I was. You know you go through the fasting and purging the night before that procedure so when it is done you are really, really hungry! I left the Doctors office and hit a nice restaurant close by and had a large bacon cheeseburger with fries and a Chocolate shake. It was fantastic for about 45 minutes and then it came rushing out the wrong end. I guess it is in the fine print to introduce food slowly and eat Yogurt for crying out loud, I missed that advice. Took 4-5 days for the intestines to calm down. All the under 50 crowd on this forum have so much to look forward to! Now back to current programming and the trailer hub.
63 Skier
From bearings and spindles and washers to colonoscopies and purging and bacon cheeseburgers rushing out the wrong end .....
That was not right on my part to mention a colonoscopy............I meant to say a prostate biopsy but I seem to mix the 2 things up. They both start out on the same entrance ramp to the "Hershey Highway" but obviously you take different exit ramps to get to where you're going with that camera and other hardware
Any update on the Trailer issue Mark? I've been thinking about your issue and wondering what the mechanics found. Have a great weekend.
ultrarunner
Hey gang, it was to go into the shop today. Should have the intel tomorrow.
ultrarunner
Mid-Atlantic got a bit jammed up last week, so they're going to take a look this week. They've also go the go-ahead to pull apart the left side and IRAN.
Did Mid Atlantic fall asleep on your repair?
ultrarunner
YES!:-(
Short of wrench-turners combined with a couple of their rental boats needing repairs. They have committed to getting me an estimate this week and back together end of next. We’ll see... Oh all right |
Sorry, that stinks but we are in the busy season.
Have you thought of a road trip and doing the repair. That is tough with it so far away.
