  New Posts New Posts RSS Feed - oily mess
oily mess
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: oily mess
    Posted: July-22-2021 at 9:22am
Naturally one week before our summer mini vacation I find this Cry  One more bolt to go- surprisingly the V drive came out easier than the trans so far
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2021 at 9:40am
Gary,
Is it the Walters with the leak? If so, make sure you get their "super special no one else has them" seals. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2021 at 10:14am
Seems to me that if the V Drive was leaking, he wouldn't be worried about getting the transmission out Wink
And the Walters doesn't leak red stuff either
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2021 at 10:19am
I wish - the vdrive was way easier to remove than the trans. The tell tail sign is the red fluid in the bilge,only the trans uses it. The Walter's use non detergent oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2021 at 12:31pm
Any clue where your leak starts?  Maybe the cooler?  Good Luck
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2021 at 1:07pm
oh rat farts
I hope it works out
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2021 at 1:51pm
Thanks for the support- just got to power through it,seems like everything is breaking this year. Got it up on the bench and parts ordered- Skidim has everything in stock and is sending right out. It's a paper gasket between the front cover and the case. The pump mounts to that front "cover" - so as I understand from Zach who's walking me through this,the pump can stay in place but as I remove that front cover the drum comes out as well. So I'll get that all apart so that when the parts get here it can just go back together. Still got time- crossing my fingers. Number 18 in this picture-
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2021 at 10:52pm
Hats off to Skidim they sent out the parts yesterday UPS second day air-they arrived around 1030 this morning. Replaced the gasket,pulled the pump to replace the shaft seal and 3 o rings since it was that far apart. Did all of that in the garage while waiting for the boat to get shade, hot and humid all day. Could have got farther but when I needed that 3rd hand everyone was busy which was for the best as I could cool off. Zach warned me ahead of time but so far the hardest part was re installing that front cover,when you remove it the input shaft and the drum comes with it. When it goes back in the input shaft drops into a bearing and the drum has to align with the teeth of the clutch plates. Took several tries but finally popped right in. Now have to finish up the mounts,hoses,minor electrical and align. Should be ready to test tomorrow. Engine crane saved my back- sure has earned its keep.First I lift the trans off the bench, wheel it over to the boat then in on a 2x6 across the floor. I'm having a new pier put in,the guys doing it gave me a 5 foot section of 4" pipe that was left over. Slipped it over the engine hoist boom which than extended it enough to easily reach the center of the boat to do the heavy lifting. Since the angle is not as great as when getting it into the boat I don't have to worry about the sling slipping. Good thing I work cheap I think this would have been a expensive,long down time repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2021 at 11:04pm
You have nothing but time
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2021 at 11:13pm
I have to be on the road by Wednesday to make it to Bubba's for lunch on Thursday......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2021 at 11:15pm
Good thing is you can drive your car straight to bubbas
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2021 at 11:40pm
Nice work Gary, I really like the team red colors!
PS. I have a similar hoist, I added a swivel hook to the hoist, it allows me to swivel the load smoothly 360* and made a big difference in usefulness.  I think the 2,000 lb swivel ran $50 but worth every penny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 6:32am
Thumbs Up  Thumbs Up
Gary,
Was the seal bad or did the shaft have any corrosion?  Ether way, great you got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 7:50am
Wow..... I'm impressed.... And to think you used to repair telephone land lines. You've come a long way young man. Looks like going to the gym has paid off too. Retirement is good to you Mr.Starr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 9:39am
Pete that is what makes me nervous. There was some corrosion on the shaft which I cleaned with crocus cloth provided by IBT many years ago ;) but there was no oil in the bellhousing or anywhere on front end of the trans. Hoses and fittings were perfectly dry, cooler dry. Bottom inch of trans soaked, you could see oil in the seam. Gasket hard and brittle when removed but intact.
Tim in my young days I didn’t know what I wanted to do thought a automotive mechanic might be in the future. My dad said do you want to be standing under a car with the melting snow dripping on you when your in your 50’s?? Mom pushed me to the phone company since she had worked there many years before. Today marks 39 years that the young lady I met there have been married- she is spending the day watching her mom, I’m spending it in the boat.
Mark thanks- you great taste in colors ;) I don’t think I paid more than 150 for that HF hoist it really has come in handy, 150 does not go far at the chiropractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 9:57am
Gary,
We'll be crossing our fingers hoping for the best.
I just looked at the picture again and it sure doesn't look like you're down south! Did you come north to cool down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 10:35am
This job would be impossible down there,I had just the very minimal tool selection there or even the room to do this. Besides with that salt water this poor boat would have been a mess- fresh Fox River water only for this boat LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 10:52am
Gary  - Do you think the gasket failure was just old age or was there another factor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 10:52pm
My old age or the gasket Chris LOL. I wonder if it relaxed and had it been able to be re torqued if it would have been ok?  Don't know- like I said I wish the problem jumped right out at me. Anyway just walked in about a hour ago completely done. Cleaned up the bilge earlier and test ran it on the hose going for a water test in the am. Got it aligned don't know how or even understand the whole system- why is the engine and trans rubber mounted but the v drive which is mounted to the back of the trans has it's own mounts that are rigidly attached to the "stringers" Confused I would think that would transmit noise and vibrations into the structure of the hull. Anyway got it to turn with one finger which is better than it ever was, sure is alot of stuff turning compared to a DD!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2021 at 11:56pm
Gary, a young man would have struggled to get all that done in a couple days.  You kicked some serious A**.   Nice work.   Hope the water test is equally impressive.  Your mount comments has me thinking you may have found why the gasket failed.  Paper gaskets seal pretty well but allow for zero movement.  Vibration may have took it out.  Have a cold beer or 6 and celebrate your win.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2021 at 10:34am
Success !
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2021 at 10:40am
Success !
Clap Clap Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2021 at 11:41am
Great glad you got it fixed.
 I don’t think I’d ever want an ass-pusher just because how difficult they are to get at when things go bad. Thumbs Down
PS;  Why does it take you 24 hrs to get to bubbas, your not in the Deep South anymore? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2021 at 5:09pm
WOW,
I am impressed that you tackled that project yourself. You should be proud of yourself. Those ensure drinks must be keeping you fit. LOL !!!!
Donald
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2021 at 7:42pm
Cousin Don, Quinner and I have a master plan to come down and have the Chicago Chapter of CCF take over your operation. As you know he's already there setting up, it won't be long now we've both been bulking up- we'll see who laughs last.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2021 at 9:01am
Gary,
Yes, about two weeks ago, I spent a full day with Quinner drinking adult beverages and floating in the lake. I took my female Chocolate Lab with me and Chris had is Male Yellow Lab with him. Before arrival, I warned my female dog that both Qunnier and his male dog are very likely to try to hump you so please be on high alert.  LOL  It was hard to keep an eye on both of them at the same time, I am happy to report, no puppies were made.
Donald
flyweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2024 at 9:38am
Gary. Hope you are still "hanging around" this thread. I know it's old.  We just picked up a 95 super sport today, for a can't pass up price. The motor has thrown a rod, and the oil pan has a hole in the side of it to verify that fact.  We are going to pull the engine and replace the lower end with a remanufactured one.  I am just wondering, can we unbolt the transmission from the engine in the boat, and then just lift the engine out?  We'd like to leave the Vdrive in place and in tact if that's possible.  It looks like there is room to unbolt the PCM transmission from the engine to do this, but since you have pretty much been through all of this already, we figured we would get your thoughts and help as to the easiest way to get the engine out. We do have engine hoists and all of that, as we have full access to a Diesel engine shop.
Drink Tonight..for tomorrow We Ride!
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2024 at 9:48am
I have seen people do that. not how i would do it but for me getting the whole power plant up and on a skid works better for major component replacement. the 95 supersport with the walters v-drive can be a handfull getting it up out of the engine bay in one long unit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2024 at 2:40pm
FL - yeah the engine with transmission and V drive gets to be a long piece of hardware, so we are hoping we can unbolt the engine block from the transmission leaving the tranny and V drive in the boat, and lift the engine up and out.  That would be ideal.
Dan
