holman moody 302 |
93/70 ccpb ![]() Senior Member ![]() ![]() Joined: March-05-2006 Location: United States Status: Offline Points: 448 |
![]() ![]() ![]() ![]() ![]() Posted: July-23-2021 at 7:43pm |
color code for holman moody blue?
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21207 |
What year? They differed
tim i think its a 68 has lighter blue not the real dark blue
I want to say “old Ford blue” might be close, I know reid will remember. Believe the interceptors of that vintage used “Ford dark blue”.
Mine had a bunch of colors on it- it was hard to decipher. There was no light blue but it did have a dark blue and someone thought black looked good on parts of it. I went with the dark because I liked it.
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3024 |
I do like that color, Gary. Better than the the lighter Ford “blue”.
ok thanks all i think ill go with dark blue,is going to be put on backburner till this winter.
67 ski nat ![]() Platinum Member ![]() Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1199 |
Gary beautiful engine very nice detail
Do people on dock comment when you lift doghouse |
MourningWood ![]() Gold Member ![]() Joined: June-13-2014 Location: NorCal Status: Offline Points: 920 |
I run a '69 Mustang in a vintage race group. For the Fords of the era, Duple-Color DE1606 seems to be the engine paint of choice.
'I measured twice, cut three times, and it's still too short!" |
if i change from left hand to right hand rotation what do i need,,(right hand dist ,right hand cam, right hand starter)anything else?
pjsmoreno ![]() Senior Member ![]() Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 200 |
Wow like that dark blue on that engine! Great choice.....
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11236 |
you'll need a RH crankshaft because the normal rotation crankshaft has knurling/wick/helix lines going the other direction at the rear main seal and you'll have an oil leak. Or......you get the lines machined out or a speedi sleeve installed and hope the smooth 2 pc rear main seal seal works. Gary S can tell you what he went through and did for a non leaking rear main seal or here's a link to an old thread where he mentions it. And only a RH distributor gear for your present distributor
