1985 CC Trailer repair |
GeoB ![]() Newbie ![]() Joined: July-12-2021 Location: Connecticutt Status: Offline Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: August-01-2021 at 7:36pm |
Hi, new to forum. Just found the trailer for an 85 SN that I purchased on a lake.
Hubs leaking. I pulled bearings and seals I’m looking at parts online and can not ID the parts needed. What weight was this trailer built for? Kits are listed as 2,500-3,500 or 5,200-5,000 pound trailers. |
Geo
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
If you have 6 lugs you have a 5200-6000 lb package
Wouldn’t hurt to measure what you got and compare to what you get. |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3030 |
Take the old bearing and races to a good auto parts shop -- like NAPA. They should be able to help.
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5334 |
NAPA Part #'s included in this thread along with a couple of other links
This thread is also loaded with 89 trailer info which may match your 85 6-lug. I’ve heard somewhere there are 2 size drums/hubs which could impact the OD of your inner bearing.
https://www.correctcraftfan.com/forum/forum_posts.asp?TID=16419&title=89-correct-craft-trailer-repair |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21210 |
*outer bearing
Spindle is the same on 5200/6000 lb axle… just the outer bearing/hub is different. |
