  New Posts New Posts RSS Feed - 1965 Nautique Update
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2020 at 2:21pm
Originally posted by 70CC 70CC wrote:
. The 70's era dash mounted ski mirror is for sale.
Gary,
Thanks. I sure missed that one!
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2020 at 3:40pm
Been a while since I've posted, but just wanted to say the boat is looking great!
Hilarious that you referenced my 67 build in your first post. I have made zero progress on my boat since right about the time of your post (5 years ago). Seeing your progress is giving me some encouragement to get back to work though.
Craig
67 SN
73 SN
99 Sport
85SN
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2020 at 5:48pm
Very Very nice Phil.
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2020 at 7:51pm
Thanks Phil - two of the pitots are from your kit.
Pete - the bracket for the original mirror is still attached to the windshield. I bought a taylormade mirror on ebay that is in nice shape and was pretty cheap since it was missing the mounting bracket. Must have been destiny to bring them together.
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2020 at 10:33pm
Here's the ski mirror - correct mirror attaching to the original bracket.
Blower, vents, gas tank installed and wired up. Just need to hook up the stern light.
A few more things to take care of: Install fuel pump and line to carb, add electric choke to carb, install alternator, exhaust manifolds, and drop in the distributor...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2020 at 3:07pm
You were right they look good back there.
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2020 at 6:19pm
Working on the alternator and exhaust manifolds.
A Motorcraft automotive unit came with the boat - I've replaced it with a modern 1 wire alternator. After moving the old pulley to the new alternator, everything will line up with the addition of a 1" spacer.
Here's what the exhaust manifold cap and riser gaskets look like. I don't think there is a source for these, but I've heard you can buy gasket material from NAPA. Does anyone have a part number?
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2020 at 4:00pm
Still making slow progress...  exhaust manifolds, carb, alternator, are installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2020 at 5:00pm
Looks great! 👍🏻👍🏻
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2020 at 1:21pm
Some updated pics of the helm and new front seat - my boat likely left the factory with throwable cushions for the bottom and a snap in back cushion but I had the new upholstery attached to the plywood.   The last pic was taken by the PO prior to disassembly.
The dual speedo mounting plate is original to the boat and would have had aqua-meter gauges mounted to it (one 45 MPH, the other 55 MPH.  Looking at the base, one of them was surface mount, the other flush mount)  - when I got the boat it had, 5" 50 MPH airguides which hung over the edges of the plate -  It now has two 4" 45 MPH Airguides.  You can barely see the hand shift next to the steering wheel and the Morse hand throttle (a $29.95 option)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2020 at 5:06pm
Beautiful thank you. I needed that
I re-fab’d my alternator bracket too this summer, started twisting
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2020 at 5:12pm
So sweet I’m gonna post again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2020 at 7:35pm
Looking good
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2021 at 10:04pm
At long last... the '65 is in the water and running again! (after at least 30 years, 11 of those in my possession)
Initial start on a garden hose went well until it started to rain, Next I dipped the boat in the Cedar River on the trailer to finish breaking in the cam, test the complete raw water system and transmission shifting.  Found my thermostat housing was leaking, fixed that, then trailered to Lake Delhi for the shake down cruise.
Docked next to the 97:
Running down river about 25 MPH
Thanks to Keith and everyone on CCFan that has helped with this project and provided moral support along the way, especially Art who found the original bill of sale and helped with the missing puzzle pieces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 5:40am
Phil,
Fantastic to say the very least. I knew you'd get it in the water one of these days. Looks great. Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 8:31am
Beautiful Boat!  Very nice work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 8:46am
Phil,
Keep us informed on how that FE runs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 9:35am
Bad ass. Very happy for you. Beauty
Thanks for action pictures
-brother from a different mother-
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 10:04am
WOW nice work and thanks for sharing this.
1968 Ski Nautique, Project.
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 10:39am
Phil - That is so AWESOME.  Can't wait to hear how she continues to run.  GREAT WORK!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 11:29am
Way to go Phil!  long journey but worth it Thumbs Up
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2021 at 12:14pm
I've been taking it easy breaking in the motor, but so far I'm pretty happy with the way the 390 is running.
The distributor is a Mallory marine unit with points.  I'm running a Carter 4 BBL (I believe this to be the original carb) converted to electric choke.  Idle is smooth, throttle response is nice and snappy with no bog.
I have to give a shout out to Gary Myers from Motorheads Mfg in Ely for doing the machine work and assembly, working with parts from multiple motors.
Mojo View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2021 at 8:34am
Thumbs UpBeerThumbs Up
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2021 at 12:17pm
That is a beautiful boat, you guys that do the period correct/showroom restorations have skill and patience on a whole nother level.
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2021 at 10:06am
I'm looking for a few items to finish off this project:
The Ski Nautique script that goes on dash is broken in two pieces.  I believe its the same emblem used on the Gen 2 boats, and maybe even the 2001's?
My 71C does not have a neutral safety switch.  If anyone has a junk Velvet Drive laying around, I'm interested in the switch, the mounting plate, and the cam that actuates the switch (like the one shown here).
Send me pm if you have either of these.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2021 at 10:19am
I believe the neutral switch is still available new. I found one on eBay, bought one as a spare
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2021 at 10:23am
Try. 1000-640-004. Velvet neutral switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2021 at 10:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2021 at 12:12pm
Like he mentioned he needs the cover/mounting plate and the cam too, not just a switch  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2021 at 2:33pm
Phil
I dug through my "pile of parts that might come in handy for somebody one day" and came up with what's in the picture.
It's the cam and the plate you need.
I found a dead switch, but that won't do you any good.
This plate takes the newer NSS that has a 7/8 hex head. The PCM part number is R153011 for the switch. The part number listed and linked earlier will fit. There's a wide variety of prices when you get looking.
It's cheaper than the old bigger switch too Wink
Send me a PM with your address and they'll be on the way to Iowa for a worthy boat.
We'll call it a donation to your project
