1965 Nautique Update |
Page <1 234 |
70CC ![]() Senior Member ![]() ![]() Joined: June-12-2006 Location: United States Status: Offline Points: 338 |
Fantastic! PM sent. Thanks!
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 10810 |
The USPS has the package now, says it'll be there on Wednesday.
I'll send a tracking number in a PM later today
Velvet drive updated with neutral safety switch - thanks again to Ken. Motor box and rear hatch cover added.
Pulling its first skier in about 30 years...
Beautiful Phil
Phil,
Thanks for all your efforts into a fantastic restoration.
67 ski nat ![]() Platinum Member ![]() Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1189 |
Very nice 65, well done sir
Next years calender entry winner
63 Skier ![]() Grand Poobah ![]() ![]() Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4256 |
Boat looks amazing, and love the picture with the skier! If it's possible for a boat to be smiling, that one is.
samudj01 ![]() Gold Member ![]() ![]() Joined: March-10-2009 Location: NC Status: Offline Points: 968 |
Awesome to see it back pulling skiers. A job well done.
davidg ![]() Grand Poobah ![]() ![]() Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Sweet boat! Very nice work. I bet that 390 sounds sweet! Love them FE motors.
It's been awhile since I've posted. Here's an update on the '65 Nautique:
Last summer the rebuilt 71C transmission with maybe 10 hours of use failed. I was pulling into the boat lift, went into reverse to slow down, and the boat stalled. Went to neutral, started the boat, and it lurched forward, almost going through the lift - that would have been bad! Shifting into reverse stalled the boat again. After getting the boat safely on the lift I determined the transmission was stuck in forward. Could have been so much worse as I think of the times where I have pulled up to a dock, counting on reverse to slow me down. Well that was it for summer of 2022. Fortunately, I had a spare 71C from one of the marine engines that I bought for parts. It was an early unit mated to an early FE in unknown condition. At least the fluid looked OK and so I thought it was worth giving a try. At a minimum it would be a place-holder to attach the motor mounts to and hold up the rear of the motor while working on the failed transmission. Degreased, and with a quick shot of paint to match the motor, it was ready to install. ![]() The swap went well. I used some lifting ears that came with one of the engines to suspend the rear of the motor. Glad I installed studs in place of the lowest two bolts when the first transmission was installed to help guide the transmission into place. After getting things bolted up, I went to the boat ramp. Boat started, no leaks, so far so good. Let it warm up, then checked forward and reverse. Still no leaks and seemed to be going into gear properly. Checked and added some fluid and took a cruise, everything worked fine. I now have a couple of hours of cruising and all seems to be ok. One of my winter projects will be tearing into the transmission that I pulled out to find out what happened and hopefully can fix it.
Nice to have a spare on hand to swap in there, and even nicer that it ended up working. Great to see that boat getting used in 2023, 57 years old if I did the math correctly.
Page <1 234 |
