  New Posts New Posts RSS Feed - Dampener plate question
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Topic: Dampener plate question
    Posted: November-01-2021 at 1:58pm
'94 SN PCM 351/1.23, 750 hrs......
Inspecting the dampener plate. Triangular, rivets tight, no broken/cracked springs, but a little play in them. Don 't now if original or previously replaced.
question: Should the springs be held tightly?
Thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 5:21pm
Bueller? ....anyone.....?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 6:46pm
It's Bueller's day off
I figure that's one of those damned if you do, damned if you don't type of things.
You may think it's good, put it back in and a handful of hours later it blows itself apart or maybe it's good for another 1000 hours.
Being 27 years old,and not knowing if it's original, most people would say to replace it while things are apart.
How many hours are on the boat?  Edit....I see 750 in the first post
I'll say low hours, little play............reuse it. But don't blame me if it falls apart.
It's what I'd probably do, not necessarily what you should do Wink
I figure that'll probably make you want to replace it or if nothing else generate some opinions for your thread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 7:17pm
As always, sage advice. Since I can now remove the engine/trans unit in less than 30 min.....I'll be takin' me chances on the plate. I've not yet driven this thing, so I'll be listening...thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 7:19pm
I'm not sure I've ever seen a triangular PCM 15 spline plate, could you post a picture of it?
Is there a part number anywhere on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 9:57pm
I reused mine during my transmission fiasco this summer. I felt that I just did not have the time available to pull all that extra stuff off. I have something like half the hours you do though. That one looks so nice and since your comfortable with pulling the trans that if it were me I think I'd give it a go. I also have to fully disclose that I have not replaced a damper in any inboard I own,they may even have the originals
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2021 at 5:57am
Well, after a long and semi exhaustive search, I stumbled into the video in the link from SkiDim.
He's doing the plate on a same era ProTec engine like yours and the plate looks just like yours and seems to be the original that's been changed in later years to the full round plate.
So now I've seen pictures of 2 of them Wink
He's gonna reuse the one in the video since it didn't have much play
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2021 at 10:38am
OK, I guess I should've searched longer than 15 sec.
Or maybe typed "PCM marine flex plate removal" in google.......Wink
But thank you for that vid link which, while eerily familiar, shows the same plate and a brief inspection thereof.
Now we're both exhausted
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2021 at 12:15pm
Vince has been pumpin' out  videos lately.
So has Ron Tanis at skiboatpartsonline
