  New Posts New Posts RSS Feed - CC Trailer bolt pattern
Daveinater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveinater Quote  Post ReplyReply Direct Link To This Post Topic: CC Trailer bolt pattern
    Posted: March-03-2022 at 7:44am
Howdy all,
I have a 1992 Sport Nautique on a factory single axle trailer.  I’m the 3rd owner and have had it for years.  I’ve never been a fan of this trailer, probably for no good reason (just wished I had a dual axle) but over the years I’ve rebuilt the surge brakes (and then recently disabled them because I hate them so much lol), redone all the wiring, replaced all lamps with LED’s, recovered the bunks, replaced the rotting wood with diamond plate, and then finally figured I was good.
Nope.
This last summer I had a blowout on the busiest part of Interstate 85 North of Atlanta, with semi trucks zooming by doing 80 mph.   So not fun.  About $750 later (Roadside service plus two new tires….all installed on the side of the freeway….best $750 I’ve spent 😬).
So it appears I WASNT done.  I need to find and add a spare tire to my #$@%! trailer.  Lol.  Honestly I should have thought to do this years ago.
Does anyone know the bolt pattern for these CC trailers?  And has anyone added a spare to this trailer, and where/how?
Thanks much all.
Dave
(Not sure why the system keeps flipping my blowout photo sideways but whatever. Lol)
MechGaT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MechGaT Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 8:05am
I have a 92 Sport Nautique on a Ramlin single axle trailer. I added a spare tire carrier to the frame under the bow. I think I got it off Amazon, but it has been a few years. I don’t trust my memory on bolt pattern I know it is 6 and you can see that in your picture. I am fairly certain mine were on 5.5” diameter. If you can get to your trailer the best thing to do is measure real quick from bolt center to the center of the one across from it.
'92 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveinater Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 8:46am
Thanks for the reply!
I know that CC had someone making their trailers for them until about '92 or '93 (if memory serves me) and it was something like "Orange Trailers" or something like that.  So I'm thinking you may have gotten the newer version.  Does yours look like mine?  I'd measure but, unfortunately, the boat is several hours' drive away.  Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveinater Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 9:11am
Ok did some digging around.  The CCF "Search" function didn't help me (thus my post) but using Google/CCF I found a post where these trailers used a 6x5.5 wheel.  The "H78-15" tire translates to a 225/75/15 (which is good, as that's the tire the roadside guy put on, 10 ply).  So I think I have what I need to order a wheel.
Question:  The standard center bore appears to be 4.25" (109 mm).  I assume that'll work with the trailer?
Lastly, any suggestions on mounting on the trailer would be great.  Not a whole lot of room for it.
Thanks,
Dave
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 10:06am
I have one mounted near the front just behind the bow stop.  I ordered a new wheel a couple of years ago.  I am trying to find the receipt.  I will post it if I find it.
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveinater Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 10:12am
Oh that is perfect!  Thanks.  Do you happen to remember where you got the mount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 10:14am
99 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 10:15am
No but etrailer should have them
99 Pro Air
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 10:20am
Fulton High-Mount Spare Tire Carrier (bolt on).  www.etrailer.com
This is the unit that I have on my trailer.  My wheels have a lug pattern of 5 on 4 1/2 but I can see that you have a 6-lug pattern.  There are spare tire carriers / mounts that will fit your wheels.  For reference, this is what it looks like with a tire mounted:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 10:49am
Most of my trailers are 6 lug, this is my go-to spare carrier.
Fulton Hi-Mount Spare Tire Carrier - Fits 4-, 5-, and 6-Lug Wheels
Item # FHDSTC0101
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 11:15am
 You mean you actually own more than one that's on a trailer and not between two trees? Tongue
Pics or it didn't happen!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 12:00pm
Also, I gutted my brakes years ago and then swapped out the entire axle assembly for a straight axle without brakes.  I tow with either my F-150 or RV and have never felt the need for trailer brakes.
99 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 12:15pm
I have a trailer that has 2 more trailers on it. I didn’t even use the trees, a simple engine hoist/crane/picker did the job.
pjsmoreno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 12:20pm
There was one time I was pulling our boat to the lake for a vacation trip and some guy decide to just stop on the highway. Surprise that I was able to stop without hitting him and surge bakes kept the trailer align with the truck. Scariest situation I ever been in while traveling with our boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 12:25pm
I really like the looks of the dual axle trailer but for practicality the single axle is much easier to move the boat around in tight spaces.  My last two boats are on dual axle trailers and in my world I am always needing to pull or push the boat into very tight spaces and on all those sharp turns the single axle works much easier, there is a good and bad trade off with the dual axle set ups.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 1:08pm
+1 on Surge brakes!!!!!!!
The 88' is on a 87 trailer and for the longest time I wished I had them as there were many times the pucker factor was off the charts because some Clown pulled out in front of me or swerved in my lane I've almost tagged a few cars....... Boatmate Trailers added surge brakes for me a few years ago and it was the second best thing I did for that boat.  Money well spent as they've saved a few fender benders for sure. First best thing was going with a Acme 540.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2022 at 4:41pm
Like Morfoot said, a picture of this trailer threesome is needed to go with the rigging masterpiece below. Wink
Daveinater could probably use a closeup of that classy wheel too
Post Options Post Options   Thanks (0) Thanks(0)   Quote MechGaT Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2022 at 10:03pm
It took me a while to get some pictures and logon to my computer, but here are some pictures of my spare tire mount.
spare tire mount front view
'92 Sport Nautique
Wilhelm Hertzog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilhelm Hertzog Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2022 at 1:16am
Here's my spare tire mount. I had it made by a local trailer builder a few years ago. Works well so far.
Do not go gentle into that good night. Rage, rage against the dying of the light.
