Ski pylon replacement |
Wilhelm Hertzog
Senior Member Joined: June-14-2014 Location: Cape Town Status: Offline Points: 334 |
Posted: April-27-2022 at 4:50pm |
My (non-original, stainless steel) ski pylon on my 1982 2001 has bent to the point that it needs to be replaced. Due to shipping charges to South Africa, buying a factory replacement pylon from Nautiqueparts.com or the like is going to be multiples more expensive for me than having a replacement made locally.
I basically have to decide between going stainless steel again (but using thicker walled tube this time), or aluminium. I can't get any of the preferred grades of aluminium locally. The only grade I can get is 6063 - which seems to be even weaker than 6061. Any recommendations on which to go with: stainless or 6063 aluminium? Thanks as always for any and all input and advice!
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11053 |
I'd kinda figure that if you start with a 2 1/2 inch diameter piece of round aluminum solid bar stock, no matter what the grade, it'll be plenty strong for whatever you might be pulling with it
