  New Posts New Posts RSS Feed - PCM 351w intake mainfold
JoeJoko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeJoko Quote  Post ReplyReply Direct Link To This Post Topic: PCM 351w intake mainfold
    Posted: August-08-2022 at 2:35pm
Hi everyone, I've been following the forum for a few years and this is my first post. I drive a Ski Nautique 2001 with a Ford PCM 351w that I have completely restored. Now to my question: for what is this oval hole on the intake manifold? Do I have to close it with my gasket? I have a spacer between the intake manifold and the carburetor. is the same gasket above and below the spacer?
thanks in advance for your commentsSmile
best regards from Germany
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2022 at 9:14pm
I believe that you are referring to the Exhaust Crossover.  Those can be blocked off.  Some intake manifold gasket kits will include a block off option.
Wo wohnen Sie in Deutchland?  Meine Mutter kommt aus Hildesheim bei Hannover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeJoko Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2022 at 3:12pm
Hi Jonny, thanks for your answer.... I live close to Rostock
