Water pump not sucking |
Tbarile
Groupie Joined: May-10-2020 Location: Indiana Status: Offline Points: 55 |
Posted: September-06-2022 at 10:23am |
I have an 02 ski Nautique with the GT40. Went to ski this morning and boat overheated. Immediately assumed it was the impeller but when I took the pump apart the impeller was in great shape. Reinstalled and it’s still not sucking water. I’ve check hoses and all seem right. What am I missing?
Thanks |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
I had an impeller failure recently. The impeller looked fine but the bonding between the rubber and the metal hub had failed so the impeller wasn't spinning just the hub. A few other members have experienced this failure also. Otherwise you may have an air leak between the pump and the pickup. Do a forum search. Lot's of cooling system info on this site.
92 SN - Owned since 93
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11112 |
Hook a hose from your pump suction to a 5 gallon bucket of water on the floor of the boat and start the engine.
You'll know very shortly after that if the pump is working. It pumps roughly 5 gallons/minute at idle It'll at least tell you if the problem is pump related or is an air leak or blockage before the pump
