Winterizing.. |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1811 |
Posted: September-18-2022 at 11:27am |
I find it interesting Ron Tanis promotes laying up the engine in a dry state. Good point on the t-stat comment. Thoughts?
Shouldn't there be a link or something here.? It must be time to start kicking the dead winterizing horse in the head once again
ultrarunner
https://youtu.be/0PbDqI2glPA
Well, Ron talks about an engine full of water with the thermostat closed.
Like he said that'll be a problem Now take that same engine full of water, drain the engine and the manifolds, close up all the drain paths and suck up let's say 5 or 6 gallons of antifreeze and you'll fill the engine even with the thermostat shut and you'll fill the manifolds too, after the engine fills, then you'll have antifreeze coming out the back and you turn the engine off. Then you can leave it, drain it or whatever you want to do It's all been gone through numerous times here on CCF.
ultrarunner
Exactly. I was just surprised he’s a proponent of just draining only. He did build my fist ski boat, which I still miss to this day :-(
Drain only club here
Tomrupp
Groupie Joined: October-14-2021 Location: MI Status: Offline Points: 78 |
I’m a drain first. Run 5 or 6 gallons of anti freeze into it and drain it again kinda winterizer.
Tom
94 Ski Nautique Open Bow 351 with Carb 95 Double Decker Aqua Patio with 50hp Honda (3 carbs). |
I just park it in a temperature/humidity climate controlled storage, never had a problem.
pjsmoreno
Senior Member Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 169 |
I'm a drain only club guy also...so thankful for my heated garage...
Question, Does adding antifreeze with a corrosion inhibitor after draining also help keep the cast block and heads from rusting?
That’s a great question for KENO
rebel skier
Gold Member Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 772 |
I am an "air don't freeze" guy -- the fraternal twin of the drain only guys.
uncle-buck
Senior Member Joined: June-14-2004 Location: United States Status: Offline Points: 318 |
Drain only here on the Texas Gulf Coast. Installed easy drains in the engine block, exhaust manifolds, and under the thermostat housing a few years ago.
No problems during the big freeze in early 2021. May have simply gotten lucky... |
1990 Ski Nautique (original owner)
PCM 351W with D.U.I. |
desertskier
I just leave my engine running all winter.
92 SN - Owned since 93
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
Me too. I think we should recommend this to all winterizing questions. I also hook up the raw water pump inlet to a hot tub, and the exhaust water pumps back into the tub. Toasty.
63 Skier
So that I can be completely inconsistent, I drain only my '63 and drain and pump antifreeze into my '98. Except years I have warm storage for my '98, in which case I do neither.
My new "Woke" boat I'm waiting to order will be all electric so I won't have to worry about these silly things.
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6111 |
Just read one of the 97 winterizing question threads over on facebook. 55 responses so far....so far. It makes my hair hurt to read many of those answers. People over there know an awful lot, sadly, most of it is somewhere between wrong, stupid and ridiculous.
63 Skier
Winterizing questions are good, it means people want to protect their boats and are willing to ask to get it figured out. Answering with bad info makes you wonder, how does that person answering get through a winter without a cracked block or manifold? Share one of the worst answers here for kicks and grins.
75 Tique
Actually it’s mostly cases of overkill vs under kill. A lot of guys saying pump 5-8 gallons of AF if not more. Some said take thermostat out. Most said pump till comes out, not explaining all that AF could be bypassing the block. One guy referred to “potable” AF. Yeah, drink up. Some CB guy drained, pumped I don’t know how many gallons then on top of all that, put a heater or bulb in box as well. There were some drain only advocates. Living in a moderate climate now, that’s all I do, as I’ll use my boat on nice winter days but the winterizing discussions with or without AF do make me wonder about the corrosion protection argument of using AF. Absolutely no one referred to the pour in method stated in the engine manual
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2869 |
At the Quest Ranch:
1. Place trailer and boat in climate-controlled garage 2. Disconnect battery 3. Open petcocks to drain block, manifolds and U-bend 4. Secure cover on boat 5. Take well-deserved nap after strenuous winterizing process. JQ
Chrissn2001
Newbie Joined: May-02-2007 Location: United States Status: Offline Points: 36 |
Wow! I'm winterizing for the first time in over a decade. I'm in central virginia, so we don't have terribly cold winters, but there are times when it can be below freezing over nights, but not usually days on end. I'm curious about this no antifreeze approach because I think it could work for me.
I also never fogged my engine, but maybe that goes back to my decade of no use? I have done the marvel mystery in the carb, but that seems inconsistently done by you guys. Thanks for the info!
