  New Posts New Posts RSS Feed - Alternator Questions
Greg_SA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Topic: Alternator Questions
    Posted: March-25-2023 at 7:47am
Hi,
I have a Prestolite alternator (not sure of the model) on my 351w 1989 Ski Nautique.
My old wiring harness (from previous owner) had the exciter wire connected to the the Indicator Light terminal of the alternator, with an inline diode (feedback diode?). Without the diode, switching the ignition off would not cut the engine. So I have left it as is for many years.
Here is a photo of a similar alternator. Which terminal is normally used for the exciter? The bottom left?
I opened my alternator, and it looks like this...
It has a post on the bottom right side ("?"), which is connected with a link wire to the Indicator Light post. This doesn't look standard? With the wire disconnected, I can't measure any continuity from the bottom right post ("?") to any other post. The link wire is in a bad state.
Can I connect my inline diode from the Indicator Light terminal to the bottom left terminal, to "make" a new Exciter terminal?
Thanks,
Greg
1989 Ski Nautique (SN2001)
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2023 at 9:31am
The similar alternator in the gloved hand, it's the lower left like you think.
Here's a link to an Arco marine page that might help with your alternator
Top left should be helpful
I'm not seeing a lower left terminal that you describe in your alternator picture
It looks like there was once an excitation  terminal that broke off maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2023 at 10:13am
Great, thanks for the link.
Yes, it looks like something was there. Under the black plastic is a metal surface. Just not sure where it goes. Or if I can just fit a new post/terminal.
Might be safest just to leave things as is...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2023 at 10:19am
I think so, Wink
