  New Posts New Posts RSS Feed - Fuel tank removal '95 SN
LooseScrew22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel tank removal '95 SN
    Posted: March-27-2023 at 11:21am
So i have noticed a bit of a fuel smell in the stern of my boat, and looks like the gasket for the fuel gauge sender is full of cracks and splits... regardless of if this is the source of the leak, i want to replace it. I removed the two straps in the front of the tank, the black brackets in the lower front of the gas tank. I loosened the hose clamps that hold the vent hose and the fuel filler hose but i have been hesitant to pull these hoses off. There's not a lot of room to move the 1.5" fuel fill hose and i am concerned it could break off the tank. I really only need to pull the tank forward enough to get access to the sender... there's a bracket on the bottom of the tank that spans the middle cavity and prevents me from just rotating the tank from the port side.
so-
(1) how best to remove the fuel filler hose without breaking something
(2) the shower pump motor was also ziptied to the gas tank strap- where do the shower pumps usually live?
Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2023 at 1:15pm
Have not pulled this specific tank but from my work on some older ones I would:
1) loosen the hose clamp on the thru-hull fuel tank vent and pull that hose off the vent
2) loosen the hose clamp on the fuel fill hose that connects to the fuel fill fitting on the deck
3) take the fuel fill off the deck (three screws I think)...this will allow the tank to slide out or give you room to remove the fuel fill hose from the tank
4) pull the tank carefully while watching for wires etc that may be zip tied tight in that area
Also, I would think about protecting the carpet where you will be puling the tank out...the tank is likely to be dirty on the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2023 at 5:40pm
Since you just did some prop shaft repacking, if you're having any thoughts however slight about doing anything with the rudder packing................now is the time to do it.
Your tank has that little sump poking out the bottom that really gets in the way if you're trying to do rudder packing with the tank in place.
If you pull the tank, the rudder work is a whole lot easier.   Wink
Only a couple or few years had that sump and yours is one of them. It's easy to see in your picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2023 at 7:00pm
yea, its probably a good idea to repack the rudder- i did also see a picture of a tank with what looked like a foam ring in it... i hope i don't have one of those.
is the process similar to shown for this '97 sport?
https://www.youtube.com/watch?v=1ntMEH1XHJc
if so, having the tank out would be beneficial. I am planning to relocate the shower pump as it was ziptied to the port side strap of the fuel tank and it rested on top of the tank.  In my research, most are located in the engine area on the port side... any reason the original installer would have placed the pump on top of the fuel tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 2:53am
I feel your pain.  I pulled the tank in my 1994.  It was a b!tch.  All hoses have to be disconnected (fill, vent, and fuel line). Space is tight.  The un-gel coated fiberglass may draw some blood on a knuckle or 2. I thought I would break a tank fitting, but those tanks are very strong.
Keep going. You're almost there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 6:33am
Since you have the sump, you'll have the foam ring unless somebody has been in there before and taken it out.
And the process is similar to the video you posted, but he didn't have to deal with the little sump
This thread in the link is probably the one you saw with pictures. The link to PN in that thread has the pictures
It also has some comments about "ease of rudder access" ,with none of them being good comments Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 7:20am
yes, that's the thread i was reading. Sounds like once i get the tank out, I will have some inspecting to do. Fingers crossed there's no hidden suprises.
Worst case scenario: if i have to replace the tank, are they even still available?
Thanks for all the info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 7:36am
I don't think you'll have to worry about replacing the tank.
You probably have a better chance of seeing Bigfoot than finding a new duplicate replacement.
If you're happy with your fuel level sending unit, keep it, if you're not then look into the magnetic reed switch type like KUS, WEMA
Generally more accurate, less bouncy and just another way to spend some more money Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 12:28pm
I repacked my rudder on my 1995 with the tank in place and it was no fun at all so great idea to do it while the tank is out.
I was advised at the time, 7 years ago to install a grease zerk on the steering rudder while I was in there.   It was not hard, drill a hole and screw in a grease zerk,  I did this but have not greased it again since.   Steering is still free and light, no drag.  If I had a do over I would buy one of the grease extensions that Moog sells.   It is optional for the GM trucks,  2000 to 2006, they supply it for the idler arm to allow you to grease the idler arm without taking the shields off the truck to gain access.   Would work well to get the rudder zerk greased without taking the rear of the boat apart.
Hang in there and the boat will be ready for play soon and better than ever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 12:54pm
yeah once i get the tank out, i plan to repack and add a zerk- thats a great idea to add a grease extender.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2023 at 2:35pm
Just had one out of a '94...no sump, but still a PITA, So while in there, do all you may ever want to...new hoses, etc. Secure the grab rail nuts, check wiring, esp. any grounds, etc. Rudder/steering as mentioned...
1994 Ski Nautique "Riot"
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2023 at 12:25pm
So i have removed the vent hose from it's fitting by the fuel filler, and have removed the fuel filler screws but it's held in place by silicone(?) and won't budge... i will try some dental floss to see if i can cut through it on the outside, but it is a royal PITA! the bilge pump discharge port is also in the way... i can see why nobody likes this job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2023 at 12:35pm
Can’t be silicone, silicone falls apart when exposed not gas fumes.   There is a product that will seal gasoline vapors.   I think it is Hylomar?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2023 at 1:25pm
Yes, so even with the fuel filler hose clamps well loosened, that hose sticks tenaciously to the filler. Spray with some penetrating oil to loosed. Twist while pulling up on filler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2023 at 1:43pm
would this have been used to seal the metal filler tube to the fiberglass body from the factory?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2023 at 4:12pm
Been there, done that.  I may have used Channel-Lock pipe pliers to help "persuade" the filler hose.  It finally came off.  Good thing my wife didn't hear a few choice words that were employed during the extraction process...
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2023 at 8:32pm
I will try the penetrating oil, but i can't even get the metal filler to seperate from the boat on the outside, i plan to run some dental floss around the lip and then i'll wrench on it and see if it loosens
thanks for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2023 at 2:50am
I didn’t pull the fuel filler from outside the hull.  I kept that in place and focused on the hose that connects to the tank.  Why do you feel that you need to pull the filler/cap assembly?
bwinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwinn Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2023 at 8:08am
90 degree pick might be helpful. Carefully ease it in, maybe with some grease on it. Better if it’s not a sharp pointed one. Work it around the hose to break bond. I haven’t actually done this on your application so might not be helpful but this is what I do with hoses often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2023 at 9:28am
With the mounting screws for the filler assembly loose like he has them, it's a lot easier to wrestle with the hose  to get it off the tank with some twisting and lifting. You're only fighting with one end of the hose while the other end at the filler can rotate and move with the filler instead of both ends of the hose being fixed to something that doesn't move.
With the hose clamps removed from the hose, you can then take the filler and hose off together pulling them up  through the deck mounting hole for the filler without kinking and bending that hose and any excessive swearing Wink
And putting it back together is a lot easier too.
Is your tank empty or close to it, it's hard to tell in the picture?
Using a wedge under the tank on the filler side to put upward pressure on the tank, hose and filler will probably pop the filler away from the deck
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2023 at 11:53am
Lots of good feedback- i don't believe there is much fuel in the tank since i ran it pretty low before putting into the garage... however pumping out the old gas is on the list of things to do...
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2023 at 9:56pm
so i was able to get the tank out of the stern. PITA for sure. i haven't yet been able to get the hose off the plastic tank... i ordered new hose so i may just cut it off. the primary reason was to replace the gasket around the fuel sender. however it was corroded on top and bottom so i ordered a replacement. the rubber seal around the fuel pump looks in decent shape... any know where those are for sale or will i need to make a new one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2023 at 8:40am
Originally posted by LooseScrew22the rubber seal around the fuel pump looks in decent shape... any know where those are for sale or will i need to make a new one?[/QUOTE LooseScrew22the rubber seal around the fuel pump looks in decent shape... any know where those are for sale or will i need to make a new one?[/QUOTE wrote:
You don't have a fuel pump in the tank, are you talking about the rubber donut or the gasket at the top of the suction assembl
You don't have a fuel pump in the tank, are you talking about the rubber donut or the gasket at the top of the suction assembly where it attaches to the tank?
How about some pictures of the tank showing all the fittings etc. to make it easier for the next guy referring to this thread, since there aren't exactly many pictures of a bare naked 95 gas tank out in the open?  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2023 at 12:04pm
i will work on compiling pictures of this ordeal.
gasket at the top of the suction assembly where it attaches to the tank - this is what i was looking to find. Is it available?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2023 at 7:22pm
That a lot of small holes to punch in a homemade gasket.Wink
I wouldn't know where to look for a new one unless there's  one collecting dust at a CC dealer somewhere.
Since you say it's in good shape, I wouldn't be afraid to reuse it with a little of your favorite gas resistant gasket sealer on both sides if you're worried about it leaking.
Something like Permatex2 or an equivalent from other companies
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2023 at 7:34pm
The Old MG cars have a fuel sender that mounts from the bottom of the tank.  British Idea.   The only thing that they have found to seal gasoline at the tank connection is Hyloamar.   I ordered a tube off Amazon and used it to seal a gas tank on a Mercedes E350.   It is good stuff and from what I read you can trust it to seal.   Some motorcycle tanks have the same problem and those guys use Hylomar also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2023 at 12:32am
It looks like its in decent shape, I'll check it and see, if its bad, i'll scan it in and see if a buddy can laser cut me a new one. Otherwise permatex it will be.
i checked the tank, i have a black foam gasket at the bottom... it appears it might be in 1 piece although it is shifted... i will post more info.
I was able to get the fuel fill hose off as well...
more to come
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2023 at 10:05pm
Updates: i don't have a lot of pictures, but here's the deal. I was able to remove the tank
After looking at the gasket and underside of the fuel sender (corroded) i ordered a new one from nautiqueparts.com. I am also replacing the all the fuel lines from the tank to the engine (reusing the vent hose) and new fuel-water seperator filter (i have the sierra 18-7845)  and i sandblasted and repainted the fuel-water filter housing.
The gasket for the fuel pickup is okay on one side, but nasty on the side where it was in contact with the aluminum. The ground wire nearly corroded all the way through the aluminum plate.
I have created a template in fusion360 for a replacement gasket and if i can find a replacement material, i will laser-cut a new gasket. I have to also clean off the underside of the fuel pickup plate.
I do have the black donut in the bottom of the tank... it came out in 1 piece and doesn't appear too crumbly but i am not sure i want to put it back in.
I plan to call correctcraft to see if they have any recommendation to deal with the foam thingy.
I will try to get more pictures soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LooseScrew22 Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2023 at 11:22am
So having talked to another member with the same tank, sounds like no need for the foam. I found my top plate to be more corroded than i expected (see picture). I contemplate JB weld, but the more i think about it, the more i think it makes sense to have a new plate fabbed and use a standard rigid plastic pickup tube.
tnplicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnplicky Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2023 at 7:20pm
I am very interested in your project.  I have been thinking about doing the same (also '95 SN) but have not pulled the trigger yet.  Have you been able to identify the source of the fuel "leak"/smell?
