New to me 93 Ski Nautique |
Page <12 |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3733 |
As Ken pointed out those Scotch Lock quick connectors are less than ideal. All trailer light kits come with those and are at best temporary. I bought some wire connectors recently and wish I had them years ago. They look like normal crimp wire connectors but have heat shrink already installed. Insert the wire ends, crimp the connector and hit it with the heat gun and you are done. Saves a lot of time and seems to be a water tight connector. They come in a variety of sizes. Reviews were 100% positive and many shops have adopted using this type connector. I formerly soldered all connections and either shrunk wrapped or taped the finished connection. I like these better.
samudj01 ![]() Gold Member ![]() ![]() Joined: March-10-2009 Location: NC Status: Offline Points: 972 |
What is the boat safe box. I see nothing having to do with speed control on this boat. I looked on google and didn’t find much on this box. What could it be there for?
Can someone post a pic of what the buzzer should look like. I have a new nautiques dash plaque and want to go back to one light and original buzzer. I plan to get back to original wiring but would like to see original setup. My original thought was that the aftermarket light was for something else, but it looks to connect to the same wires. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11015 |
I figure if you follow the wires from the Boatsafe box you'll probably find about 5 more Scotch Lock connectors and be able to figure out what original wires the thing hooks to.
Maybe somebody put the box there to deal with ignition noise etc just as a guess
davidaha ![]() Groupie ![]() Joined: May-13-2020 Location: Kansas Status: Offline Points: 45 |
Thanks for the pics. ...Today I learn that you are supposed to be able take that whole pod out on a 92.... Mine has 7-12 prior owner wires running through that don't have connectors (PP, radio, other mystery stuff...) need to figure out what each is and how I can make the pod fully removable...then rewire it to get rid of the daisy chain.
Thanks. |
92 Ski Nautique
Starting this wiring project:
Plan is to get rid of much of the daisy chain:
The blue scotch locks are for the depth finder. Leaving as is. Questions:
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21165 |
I would be careful on your nomenclature first of all- purple isn’t just “positive”, it’s keyed power. Anything that runs only when the key is on will be affected by this circuit. I would try not to daisy chain anything that draws a meaningful amount of power- gauges are fine but anything breakered/switched individually probably should be given a clean power source.
The only other bit I’ll mention is that I’d be careful not to bypass any factory breaker/fuse protection, and to make sure you’re adequately protecting your boat with breakers/fuses and wiring size choices. The methodology you should be using to size wiring and breakers is to make the wire an adequate size to feed the current draw of the component it’s feeding, and then breaker a bit below the current handling capability of the wire. |
Thanks for the initial comments...I went back and edited a bit in case someone looked at it in the future.
I plan to use the existing breakers/switches and will be using wire that is the same size or one gauge larger.
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6121 |
If you, for some odd reason, decide to do away with your PP or decide to upgrade, let me know.
Plan sounds good to me Where's the other end of the blue wire go to? They had a buzzer along with the light Cleaning the female connectors, I usually use small drill bits or taps that are just a little smaller than the hole so I can do a little scraping of the junk (Along with your favorite electrical parts cleaner) |
Larry - no PP on this boat
Ken - that blue wire is daisy chain (pos) for the gauge lights. It comes from the Nav Light breaker/switch. I’m betting the orange is for the curtesy lights. Prev owner must have removed oem alarm/buzzer. Think I’ll leave the after market. I’ll have to buy some contact cleaner. |
63 Skier ![]() Grand Poobah ![]() ![]() Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4268 |
I don't see any way to have a pizza and beer at that table, seems like a significant problem to me. On wire size, I do think at times there's a tendency to oversize wires to correct the OEM dash deficiencies. As I see it the problem is all the daisy chaining, which you are of course fixing, not that the wire used was all that undersized. Better ground is always a good idea and it can never hurt to upsize that wire.
This may not be perfect but I would have liked to have been able to look at a pic like this. (Red wires are (pos) in the pic…I should have marked). Will post an updated pic once I finish adding bus bars and removing some of the daisy chain. Boat safe box to be removed. Will leave original light and aftermarket buzzer. Will hide or remove aftermarket warning light.
Re: wire size comment above: I am adding additional 10awg positive and negative to run in parallel with original. Any new wiring I did to remove daisy chain is in 14awg instead of the factory 16awg. ![]() |
Finished the dash pod. Next is to run the new 10awg wires from the block and reinstall dash pod. My wires are a bit messy around the breakers but I think it turned out well...hard to clean it up with the daisy chain of indicator lights running everywhere. I also could have used some yellow heat shrink female spade terminals. I needed ~4. Oh well, the regular ones match from factory. Double sided tape on the back of the bus bars
New pod: ![]() Bus Bar close ups ![]() ![]() ![]() Dash Pod with notes: ![]() |
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5778 |
Holy Moly, and I thought installing 2000 wood plugs in my Collegian was tedious. Nice work David
Wired to engine and dash reinstalled. Horn is strong! Happy about that. Didn’t have the key with me so more testing to come but seemed that everything worked that runs off ign breaker.
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2937 |
A worthy project, no doubt. You'll be happy with the results.
Fuel sender replacement:
Had a fuel gauge on this boat that always read low and bounced a lot. After replacing the dash wiring and testing the gauge at the dash, I needed to replace the sender. I got lucky and a guy on Facebook had his slant back taken apart. I asked for pics of the sender as well as a tank measurement. I got a reed style sender and you buy it 1" shorter than the height of the tank. So I got a 10" sender for this 93 Ski Nautique. ![]() ![]() Not many tools needed. New sender ready to go in. ![]() Old sender disconnected and unscrewed...ready to pull out. Had to bend sender pretty good to get it to curl out. This was bc I didn't pull the tank. It is a confined space above the sender. ![]() Bent Sender to get out of tank. The float was very waterlogged with gas which is what I read to be a common cause of bad readings with these old senders ![]() I tried to bend the sender back straight to give a view of what it would have looked like in the tank. ![]() New Sender installed. Had to work a bit to get it to fit in due to the confined space but I managed. The 5 screws on top were not fun to get lined up. Installed the back ones first a couple of turns. Then the fronts. Then tightened them all up. The old screws were needed as the new ones didn't have matching threads. I trimmed all wires and used fresh heat shrink butt splices to connect them to the new sender wire. I would have liked to have had a pic like below (and I wish I had a pic of the side tabs to share) but note that the seat back slides straight up off of three tabs, one in the back and one on each side. The next pic you can see a tab on the side of the seat back. There are two carpeted boards that go in first. And the seat base bolts to the floor (you can see the starboard female side on the floor in this pic). ![]() Did all work on the lift and didn't remove anything from the boat. This pic shows the tab on the side of the seat back. The lake is very muddy after a big rain...should be back to normal soon I hope. Please ignore the muskrat poop on the dock...it is due for a cleaning this spring. And hopefully there will be an orange skier in the little slip soon. ![]() |
Might’ve asked before going through the effort… my experience on those NWZ tanks is that they are always going to read low. Seems unavoidable when using a linear sender on a triangle shaped tank.
You did clue me in on that due to the shape of the top half of the tank being angled. I get it but still think the sender was necessary. My old one was terrible. That said, if fixed, 1/2 tank will actually be closer to 3/4 and 1/4 of a tank is closer to 1/2 due to the tank shape. Mine was so bad that I would have 12gal and it would read empty...no fun when filling with a syphon hose.
My sport gauge didn't read correctly, same as you read empty from about 1/2 tank down. Finally after maybe 6 years I got tired of it and replaced it. While not a triangle, my tank is more like an L, much more capacity in the bottom 1/3 than above that. So of course the gauge isn't an accurate reflection, but once I have the experience of knowing about where I'm at for each gauge level it works fine for me.
Well Dave, just tell yourself you got a better sender than the swinging arm sender with a heavy gas saturated float
![]() One thing most people don't realize with these reed switch type gauges is that inside the tube there are a number of reed switches and the black float around the tube is a magnet that as it moves, picks up a reed switch as it goes past it. There are only a certain number of switches depending on the length, but on the typical 10 inch or so sender you'll have one switch for empty, one for full, and for example 7 in between them so your gauge only changes readings about every 1/8 of a tank.(If it was a rectangular symettrically shaped tank) So as you fill the tank, it may take some gas to start making the float actually start moving, then the level gauge responds in 1/8 tank increments. Same thing on the way down. You'll never know that you have 7/16 of a tank for example, because the gauge will jump from 3/8 to 1/2 Or if you're getting low and it's on 1/8, the next reading will be empty It won't creep down slowly. Somebody might say "that's not very accurate" compared to the swing arm type that changes resistance and the gauge reading every time it moves, but it also doesn't bounce around nearly as much as the swing arm type. So the reed switch is less sensitive, less precise or less accurate to small level changes but it's not really a problem, especially if you know how they work. |
I with you Ken, definitely an improvement and I don't mind at all the stepped readings of the reed type. |
With the number of boats you have, is it possible to run any of them out of gas if all start from full at the beginning of the summer? Asking for a friend.
Page <12 |
