  New Posts New Posts RSS Feed - Gas fill cap
Gas fill cap
swilliams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Topic: Gas fill cap
    Posted: April-16-2022 at 4:48pm
I could use an original deck fill gas cap. PO used one that doesn’t fit well. To fit a 76’ Martinique. It is the cap that has the raised tabs. I believe it to be an Attwood original deck fill. Thanks!
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2022 at 6:18pm
Since you bought one a while ago from Nautique parts that didn't fit the hole in your deck, do you know the hole size?
Here's a link to an Attwood fill assembly from Great Lakes Skipper that fits a hole size of 1 3/4 inches with more rounded tabs
or.........here's a Sea-Dog from Go2Marine with the tabs shaped like the CC cap back then, but no hole size dimension
Do you need just the cap or the whole assembly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2022 at 6:54am
Just a cap. I’ll check those out but I hate buying stuff that doesn’t fit. I thought I would check here first to see if anyone had one they could part with. Thanks Ken.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2022 at 7:21am
Bump
woodyelc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodyelc Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2022 at 2:34pm
You will find there no replacement cap for the fuel fill. Need to replace unit complete
woodyelc
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2022 at 4:42pm
Hoping someone here would have a spare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2022 at 10:32am
To the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2022 at 3:07pm
I don’t think anyone can say with any degree of confidence that the cap they have will fit your fill. I’ve seen mismatched ones of the same exact style fail to fit properly- I don’t know if it’s production variation or what.
Your best bet is to buy a complete fill as advised above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2024 at 6:37pm
Is somebody named Steve still looking for a gas cap (and filler assembly) ?
If you are, click on the EBAY link below and you'll find something that'll maybe have somewhat of a chance of threading into your filler or you could swap the whole assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2024 at 6:59pm
I think his name was Bill.  🤷🏻‍♂️ the 24 hour courtesy rule expired and I bought it.  Thanks Keno!  I hope it matches what I have. I lost the original and had to go to my parts box for a replacement and that one already had a tab broken off so hopefully the new one with two tabs should help with opening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2024 at 7:01pm
I will offer it up again if it doesn’t fit my application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2024 at 7:15pm
Now I am second guessing myself for not waiting for Steve to respond.  I may have gone out of order. If that is the case I will offer it up whether it fits my application or not.  I don’t want to be “that guy”. Steve just let me know if you still need it and it’s yours.
DenDen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DenDen Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2024 at 9:06pm
Skiboatpartsonline.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2024 at 8:05am
Den
There are piles of gas caps for sale out there that are close but don't have the same threads
Nautiqueparts sells one that's in that category. It's an aftermarket cap and filler assembly that works as long as the person is willing to do a little extra work and replace the  whole assembly and not just take the new cap and screw it into the old filler neck.
Plenty of others out there at a cheaper price than the one mentioned above from Nautiqueparts
The one that Bill bought probably has at best a 50/50 chance of screwing right in
I stumbled into it because I bought a gauge panel from a 70's  boat that had gauges, switches and labels that are the same as a mid to late 70's Ski Nautique at a "pretty cheap " price and looking at his other listings afterward, the gas cap was there.
Using some convoluted, twisted logic I figured it probably came from the same boat and maybe it would fit.
And Bill...........I'm glad somebody here on CCF  took a chance and bought it Wink
It seemed like an appropriate wait
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2024 at 8:27am
And here's another for somebody named ___________ (fill in the blank) to take a chance on Wink
It's a bit pricier
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2024 at 10:53am
Whew!!  I will rest easy now knowing my waiting period was appropriate.  I will report back on fit when I give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2024 at 10:56am
It's a bit pricier
That looks very similar as well.  I will wait on this one for while longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2024 at 6:35pm
Thanks for thinking of me and yes I’m still looking. The one on eBay does seem a bit pricey but it’s only money, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2024 at 1:35pm
Someone Posted some parts from a 1972 CC on Facebook in the Classic Correct Craft Boats forum...there is a complete gas fill and cap
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2024 at 9:10pm
Thanks, I’ll look at that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2024 at 7:28pm
Well.  The gas cap that arrived looks nothing like the picture on the eBay ad.  It does however look like the one referenced in DenDen’s post.  I sent seller a message and am patiently waiting for a response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2024 at 1:31pm
Well right about now Steve's probably glad you bought that good deal Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2024 at 4:20pm
Ha!  Yep!  the guy did say he will send me my money back.  We will see if that happens.  On another note....does anyone need a newer style gas port and cap?  Wink   LOL
