To wrap or not to wrap |
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 385 |
Posted: March-29-2024 at 10:35am |
I knew this would get your attention! Getting ready for the new season I am installing some brass quick drains on the engine block as well as in installing my engine oil pressure sensor. Question: Should I put any thread sealer or Teflon tape on the threads as I install each of those? Hope everybody here has a Happy Easter!
Otto
Morfoot
NO do NOT wrap the Boat! One Wraps gifts, pipes, and your Johnson. That's it!! NOT Boats!
Secondly, The previous owner of my 99 SN put Petcock drains in everything and used Teflon tape. No leaks that I've seen in the 2 years that I've had it. They've come in very handy in November/December when we're still skiing but yet have some 30'F temps for a day or two. Teflon tape is rated from -450'F to 500'F so I'd say your good.
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3610 |
The wrap won’t hurt anything at all but I do not see any need for it. The boat has a constant supply of fresh cooling water. There is no internal water pressure, lots of flow but near zero pressure in the open system so they do not leak.
In an open cooling system the plugs do not need to be super tight, just tighten them till snug, you will be pulling them out again at season end to drain. The plugs seal on the peaks of the threads, when you over tighten them you crush the peaks on the threads making it harder to seal in the future.
Otto Throttle
I guess my title to my thread was a little misleading I meant, rather to wrap the threads with Teflon tape or not to wrap! I would never wrap my boat she sexy, just the way she is from the factory. I was just curious about the drain fittings and the oil pressure sensor. I didn’t know what people did, so I thought I would solicit ideas! It sounds like it won’t hurt! I’ve heard that one before!
Otto
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1187 |
Actually you bring up interesting point
I always wondered about anti seize on plugs and thread seal on sensors , dielectric in distributors, other electric items Does electric current travel properly thru goops |
67 ski nat
Happy Easter !
Otto Throttle
I love dielectric! I use that on more stuff!
Permatex high temp thread sealant was also suggested…. I guess the sensor threads is the most problematic… since it actually does something! |
Otto
No tapes or goops on sensors/senders, they usually require a good path to ground.
Anything else in the water passage is fine. Hopefully your quick drains allow you to probe for sediment… have seen many, many drains plugged up with sediment that would have held water if not cleaned out. |
Gski
Newbie Joined: August-13-2021 Location: Wichita Status: Offline Points: 20 |
Having a lot of experience with hydraulics and chemical refining I prefer to us Teflon tape or liquid sealant on connections . That being said if you use them use good sense and don’t over wrap or over tighten so as not to crack or stretch treads on what ever you are doing. Also if they do leak I’m assuming you have a working bilge pump . So a small leak is no problem.
Gski
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10751 |
In pipe threads like we're talking about here, you still get that good path to ground with tape or a sealant. The metal threads still make metal to metal contact with no effect on the resistance to ground. It's pretty easy to demonstrate it to yourself with a multimeter, some goop, some tape and a few fittings So.....wrap away on that oil switch also Otto.............and quit milking the switch job from last fall
Wilhelm Hertzog
I recently did exactly the kind of testing Ken is referring to here when I replaced my temperature sender, and can confirm that tape/sealant made almost no difference to the resistance of the fittings to ground.
Otto Throttle
Damn Keno…. Nothing gets buy you! I have everything all set out… waiting to bring the boat home from storage….I will be doing my best Indy pit stop imitation!
However, that being said, I did get to go on a tour of the Nautique factory in February https://correctcraftfan.com/forum/smileys/smiley2.gif |
Otto
