Remove Cushions |
M _ Hillman
Newbie Joined: April-22-2024 Location: Portland Status: Offline Points: 3 |
Posted: April-26-2024 at 1:18pm |
I have a 2004 Air Nautique 216 TE. I need to remove the rear port side bottom cushion, to replace the skin. Does anybody have the process on how to remove those bottom cushions? Thank you, Marty.
M_Hillman
M _ Hillman
Please disregard by previous question. Found the answer buried in a "how to replace your steering cable" question.
M_Hillman
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11125 |
Now if you were to post the info that you found here in this thread, then the next guy would have an answer that's not buried somewhere else
Luigibosco75
Newbie Joined: April-24-2024 Location: 04051 Status: Offline Points: 3 |
I’m the next guy….
I have the same boat and can’t find the bolts holding the 3 bow backrests and the rear bench backrest. I got all the other pads upholstered pieces out. Thank you in advance. |
Hi new next guy
I think the back lifts straight up off of the brackets that are mounted to the hull. I also think you'll get a better answer at planetnautique.com from Nautique Jeff who runs that site. He's always dismantling interiors for restoration and should be able to tell you both answers Link to Planetnautique below And here's a link to the thread where M Hillman probably found his information and there's some info on the back seat rest removal also. It's on the "other"site too. |
Luigibosco75
I’m the next guy….
There seems to be an echo in here.....read the Keno post before yours and you should find what you need in the links to planetnautique
Luigibosco75
Yes I was having difficulty replying to Keno. Replying to Keno…. Replying to Keno….
I see, see, see.
You really will have more luck over on PN with a 2004 boat Here that's a really new boat, over there it's an old boat
