Depth Finder Addition |
mossycreek ![]() Newbie ![]() Joined: May-13-2024 Location: Nashville Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: June-02-2024 at 9:42am |
I have a 1993 sport nautique. I bought the hawkeye 2B to mount as a depth finder. One lake in particular in my area really requires it because of the terrain. I searched the forums and some people said to glue it in right behind the ski tow pole. I tired that and it didn't work. I may not have used enough glue in the bottom of the boat to give it good contact. I can try that again, but I wondered if anyone else had a thought or a picture you could share with me.
Jeff
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3005 |
I installed a Hawkeye in my 1994 Ski Nautique with good results. The spot I chose was in the starboard side of the bilge, near the side vertical wall. I needed to find water flow that was as smooth as possible for optimum function. The location I chose was not too far from the log, at the approximate spot opposite of the raw water intake.
DenDen ![]() Senior Member ![]() ![]() Joined: July-20-2023 Location: USA Status: Offline Points: 204 |
I did the exact same thing on my 75. Southwind was good results.
What is the log?
Jeff
andrewmarani ![]() Senior Member ![]() Joined: May-31-2005 Location: Baltimore, MD Status: Offline Points: 251 |
It's called the shaft log. Where the shaft comes through the hull.
Builder
Thank you guys so much. I'm going to try it later this week.
Jeff
