  New Posts New Posts RSS Feed - temperature gauge replacement
BaccoBouncer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Topic: temperature gauge replacement
    Posted: June-16-2024 at 3:13pm
Where is my best source for replacing my dash temperature gauge on my '97 sport nautique?  Number on dial body is 57509 brand teleflex(() => { window.addoncropExtensions = window.addoncropExtensions || []; window.addoncropExtensions.push({ mode: 'emulator', emulator: 'Foxified', extension: { id: 44, name: 'YouTube Downloader by Addoncrop', version: '17.2.8', date: 'March 31, 2024', }, flixmateConnected: false, }); })();
thanks
'97 21' Sport Nautique
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2024 at 3:27pm
https://www.mniboats.com/nautique-dash-pod-parts-s/115.htm?searching=Y&sort=5&cat=115&show=50&page=1
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2024 at 7:12pm
See your thermostat thread for some questions.
It seems like you may or may not need a replacement since in that thread you say you have low temperature and some bypass flow.
If you need a replacement, are you looking for exact replacement, something real close or just any gauge that'll work?
Does your original look like these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2024 at 7:43am
Yes that is my dash.  I would like to get one like the original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2024 at 9:39am
Being that the oem is nla there are a few close  looking units.
 https://nautiqueparts.com/engine-temperature-gauge-faria-replacement-old-white-black/
https://nautiqueparts.com/engine-temperature-gauge-se/
I have a 08 that the gauges are oem , I am mixing and matching on my dash..
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2024 at 12:06pm
Since those were Teleflex gauges and they aren't around any more, but the same line of gauges now has Sierra as the brand name, I'd look for a Sierra Arctic Series temperature gauge.
The bezel is white but with a little black paint and some masking tape, the bezel is easily turned black but the white face will probably be a little brighter than your 27 year old gauges Wink
The needle doesn't match, but based on your gauge experience with the original, I don't think you want to pop the bezel off of a new one.
Here's a link to the gauge...... Sierra part number 68376P
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2024 at 12:08pm
Thank You both(() => { window.addoncropExtensions = window.addoncropExtensions || []; window.addoncropExtensions.push({ mode: 'emulator', emulator: 'Foxified', extension: { id: 44, name: 'YouTube Downloader by Addoncrop', version: '17.2.8', date: 'March 31, 2024', }, flixmateConnected: false, }); })();
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2024 at 9:06pm
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2024 at 10:06am
I got this and painted the rim black.  A great match.  https://www.amazon.com/dp/B000KOVK64?psc=1&ref=ppx_yo2ov_dt_b_product_details(() => { window.addoncropExtensions = window.addoncropExtensions || []; window.addoncropExtensions.push({ mode: 'emulator', emulator: 'Foxified', extension: { id: 44, name: 'YouTube Downloader by Addoncrop', version: '17.2.10', date: 'March 31, 2024', }, flixmateConnected: false, }); })();
