  New Posts New Posts RSS Feed - Shaft Coupler gap
Shaft Coupler gap
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Topic: Shaft Coupler gap
    Posted: July-19-2024 at 11:09am
Pull the shaft back far as it will go and post a picture of both the transmission and shaft flanges please. If possibe take some measurements or be prepared to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 7:38pm
Originally posted by NeilMcG NeilMcG wrote:
Since you've apparently remastered the fine art of posting pictures around here, how about a picture of the transmission coupler showing the flange and the big retaining nut ?  Wink
Oh my...stand by. In my haste I may have missed something BIG on the trans side.
You really are psychic. I wondered if you'd comment about my newly acquired skill of posting.
Vegas oddsmakers are favoring oversize
 'Big Nut'.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 5:33pm
I have my 1995 coupler in my hand, it is identical to the second one Ken has posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 1:05pm
A little while later....here's a picture of a coupling from a 76 SN. It's made of steel.
The dished area in the middle is about 5/16 of an inch below what's being called the indexing ring and there's plenty of clearance between the output shaft and the driveshaft ends when the 2 mating faces are touching with no gap.(not a long ways apart like yours)
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 12:46pm
Here's what the transmission flange should look like.
The end of the output shaft with the blue arrow pointing to it sticks out about 1/16 of an inch beyond the flange face and there's enough of a dish in the shaft coupler that the 2 faces will touch without the output shaft touching the end of the driveshaft in the coupler.
Picture coming soon of an original shaft coupling from a 76 SN  Wink
Ignore the wheels Wink
NeilMcG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 11:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 8:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2024 at 2:35am
If you can't bring the prop shaft up to the transmission coupler and mate them something is very wrong.  Even if the alignment is quite a bit out you can move the shaft into position and mate them with a little encouragement by hand.
If yours won't mate I suspect some previous owner took a shortcut and assembled your shaft with parts that do not match.
I would have to look but I had a 1" factory Nautique coupler that only had 100 hours on it when I replaced it with an ARE shaft and coupler.  I believe the factory unit is brass, yours looks like cast iron or steel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 10:38pm
Originally posted by 67 ski nat 67 ski nat wrote:
Sure seems wrong
Can you fit together by hand, will they mate at all. Is there crap , rust needs cleaning
No. The two flanges cannot mate flush
The pic below is an old one...all of the rust has been removed.
It's the center indexing portion that has me stumped because there is no cavity on the transmission side for it to mate into. Perhaps this is simply the way it was designed with the clearances being measured between the trans flange and that inner race (for the lack of a better term.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 10:17pm
As already mentioned both halfs need to be clean.  When you bring the shaft forward they should mate up flush, no bolts in place.  When they are flush you measure the gap at all points of the clock.  You may find you have .008 at the 6 pm position while it is tight at the 12 am position or any combination.
Next you adjust your engine mounts till you get the mating surfaces to meet with no gap.  .003 is the max allowed.   I was happy to get mine down to .0015 with patient adjusting.
If you can't get the engine aligned to the shaft you might need to repair/adjust the strut.
Spin your prop shaft with it about 1/2" away from the coupler.  See where it spins with the least resistance.  You will need to support the shaft at the front, just the weight of the shaft will cause some drag in the strut.
The shaft will have a Happy Place, where it spins with the least resistance.   Hopefully this spot is pointed directly at your coupling.  If it is off you find out why and adjust.
There is a lot of information on this forum to direct you to a good alignment.
I really can't get on the alignment aspect once I get the flange situation understood. The pic shown is how it was for years...and it worked just fine. I just can't seem to figure out why there is a gap (it's not from any debris.)  It's almost as if there is an intentional gap factored into this design. This is a standard Velvet Drive 1017
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 10:09pm
Originally posted by MourningWood MourningWood wrote:
So there is an 'indexing ring' cast into the mating surface of the shaft flange, and a corresponding register in the trans flange. They fit together.  Or they should.
Try it without the bolts...
Yep, there is an indexing ring, but no female counterpart on the trans side,
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 10:08pm
Sure seems wrong
All of the rust is gone and both mating surfaces are clean. There is a circular ring on the shaft coupler side but nothing on the trans side to mate into it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 12:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 11:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2024 at 9:47am
Sure seems wrong
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2024 at 10:27pm
While trying to mate the prop shaft to the trans I realized that the two surfaces could not be flush mounted. After reviewing photos from before the restore I came across this one showing how it was originally. Is this something to be worried about? It's a tad more than .003 so I don't know what to make of this.
Thanks
