Manifold drain cocks |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1838 |
Posted: Yesterday at 12:30pm |
For those that have done it, can I see a pic of your setup? Thanks, Mark
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2958 |
Mark:
On my 2 previouis boats with the 5.8 Small Block Ford, I used these: I purchased them from McMaster-Carr: https://www.mcmaster.com/products/petcocks/drainage-valves-5/ I had one for each side of the block and one for the U-Bend (J-Bend) in the raw water system. I also replaced the cast iron plugs with brass plugs at the ends of the exhaust manifolds/risers. JQ |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11063 |
Here's a little light reading about exhaust manifold drains and corn flakes in the link below
wayoutthere
Senior Member Joined: February-28-2020 Location: Florida Status: Offline Points: 443 |
Question about this, if your installing drains on the rear of the exhaust manifolds,
I noticed quite a large build up of silt on the 79 behind those 1/2 drive plugs, granted maybe from lack of service being an orlando boat. How about routing the cooling hoses to the rear of the manifolds ? My thought is it will always flush silt out and pop the hose off for winterization, like to know if thats an option good or bad. |
