Engine / Prop Shaft Alignment |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2974 |
Posted: November-12-2024 at 11:58am |
How many perform the Engine / Prop Shaft Alignment procedure as recommended by Correct Craft:
Now I'm about to do an alignment check on the new-to-me 2003 Ski Nautique, but I'm in no mood to take her down to the lake to perform this alignment procedure. Anybody done the alignment on a trailer -- only to find that it was "off" when you put the boat in the water? JQ |
Similar
After first setting the alignment with precision, anytime even years afterwards, a quick twist of the coupling with the boat afloat gives me all the feedback i need to know all is still well, or if something moved.
I also have not had the scenario you describe where the trailer/wet alignment changed enough to move anything, even on the punkier boats |
Tom - I like the idea of doing the alignment on the trailer (warm shop) and then doing a check on the water. I may even wait until next spring for the on-the-water float test.
wayoutthere
Senior Member Joined: February-28-2020 Location: Florida Status: Offline Points: 462 |
In water a day or two (to let her settle in) after being on the hard all winter was how i was taught to check/perform an alignment but that was on cabin/sport cruiser types, except connie, she was wood and had to hang in the sling to swell up 3 or 4 days or down she'd go, such a nice riding boat that was
Also re torq the couplers over 3 passes and make sure the isolators are re installed on the marinette. In the water is the way to go but if you don"t have your own dock the other people at the public ramp get a bit agitated. |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3749 |
I have only had to do this 3 times in my life so far JQ and each time I did it on the trailer in the comfort of my garage. The shaft rotates freely by hand and no vibrations at all so I think it is just fine. I never read the part of floating the boat to do the final adjustments.
I have had to move the engine mounts on 3 boats to get alignment correct. Each time I was able to adjust to either .0015 or .001 and was very happy with the adjustments. Now you have me wondering if they would shift once in the water. Oh well it is nearly 10 years since the last adjustment and the boat has not sunk.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11093 |
That recommendation must show up on page ______ of some Correct Craft manual titled ______. (It's a fill in the blank for Jonny )
Just so we can all read what you're referring to
OK Ken...here you go:
PCM Owners Operation & Maintenance Manual (printed 11/02) Pages 44 - 46 Engine Alignment IMPORTANT: Engine alignment MUST BE RECHECKED with the boat in the water, fuel tanks full and with a normal load on the boat. Engine must be aligned so that the transmission and the propeller shaft coupling center lines are aligned, and coupling faces are parallel within 0.003 in. (0.07 mm)... JQ
Here's a link to Jonny's manual
Since it was PCM and not CC, I'd figure that's it's a CYA thing on PCM's part. It's a good thing you weren't looking at a Borg Warner transmission installation manual like the one in the link below, for their recommendations. Look at page 14 and continue on to the top of page 15 if you want some real genuine craziness. Everybody disconnects their coupling when the boat's on the trailer (or I suppose a lift would count too) right? |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1844 |
I've done it twice...once for a trans R&R, and another for an A.R.E install. Trailer both times. No issues. Nov. JQ, and I'm still on the water in CT! ;-)
Dang Mark...I'm jealous. Here it's water temp 35 degrees. Air temp 37. Too cold for a dry-suit.
That equates to a Shrink Factor 9. JQ
