  New Posts New Posts RSS Feed - Fish nautique rpm questions
Live2fish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Live2fish Quote  Post ReplyReply Direct Link To This Post Topic: Fish nautique rpm questions
    Posted: Today at 2:55am
So I’m back haha dumb questions incoming put on your helmets…
I have a 14x11 iirc prop boat hops up out of the hole doesn’t seem to struggle even with a load but seems like wide open only 23-2500rpm showing on the tach. (Could my tach be broken?)
To me seems like that’s low,
Whats a pcm 351 suppose to turn wot
How do I check I’m getting full wot on the carb??
I was cruisings around 23-25mph at 2000ish rpm until we decided to try and wot to see what we could top out at and only got it to 30mph and engine sounded like it was revving higher than tach was showing but what do I know.
I can’t open engine box while running at speed since it’s inside the cabin and it can’t be removed without taking the whole back wall off the boat wish I remembered how to post pictures on this site
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: Today at 8:40am
You could get a timing light with the rpm feature to find out if your rpm guage is not correct.
I am no expert but I would guess 4500-5000 for average WOT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: Today at 10:21am
That SBF should be able to cruise at 3,800 to 4,000 RPMs all day long.  I agree that a timing light with a tachometer is a great tool.
Assuming a 4-BBL carb, at WOT, both throttle plates (butterflies) should be vertical.  Someone will have to be operating the helm while you are looking down the throat of the carb.
If you have too much prop, the load on the engine is disproportionate for the RPM. Again assuming a 4-BBL Holley carb with the right prop, you can determine where the secondaries open.  Then just stay below that throttle setting for cruising with optimum fuel efficiency.  I realize this isn’t what you asked, but there you are…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Live2fish Quote  Post ReplyReply Direct Link To This Post Posted: Today at 1:35pm
I wish I could post a picture so you guys can see what I’m working with room wise i don’t think I can use the timing light idea. Rpm’s look sound and calculate correct up until the top end of the spectrum. The 14x11 seems to be the factory prop for my boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Live2fish Quote  Post ReplyReply Direct Link To This Post Posted: Today at 6:16pm
I was looking over videos to check and I found one where we are going 24 gps speed with tach showing 2k rpm
Punching that into a prop calculator shows a boat going 24mph with a 1:1 ratio at 2k rpm with 10% slip pitch would be 14x14.
Soooo my rpm have to be off or this props been worked :shrug:
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: Today at 7:17pm
This is like deja vu all over again
If only you bought that timing light/tach so you could have figured out that your tach is wrong a while ago and maybe even checked your timing and timing advance Wink
It'll work for what you need to do even with your setup
You can check timing and timing advance in neutral and you can check RPM with the tach lead hooked to any plug wire with no need to aim the light at anything. You can have the light outside the engine compartment where you can read RPM's while it's being driven.
