Faria Gateway & Gauges (2003-2005) |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2993 |
Posted: September-18-2024 at 2:29pm |
I have a fully functional Faria Gateway Box and full set of Faria gauges from a 2003 Ski Nautique Limited. Everything works. This Faria Gateway system will work on 2003 to 2005 Nautiques.
If your Faria Gateway or gauges are failing, this is a great plug-and-plat fix to get you back on the water fast.
I realize that a working Gateway box is quite rare as are fully functional gauges. I'm willing to discuss a reasonable price with an interested party. I would prefer to sell the entire set, and not part-out all the stuff. Feel free to send me a PM if interested. JQ |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1792 |
Did you do the upgrade Johnny? Mine is still working except for the oil pressure gauge. curious as to the conversion of new replacement set.
Winter project.
fanofccfan
I too always need a project!! Keep us updated please with a nice pictorial.
SOLD
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1859 |
Super nice JQ! Makes me want to convert my own machine!
fanofccfan
I agree. That looks great. I like that much better. Does it still offer Lake water temp? Not that the info ever got me to ski or kept me from skiing...but I did look at quite often.
fanofccfan
I am also curious if you had unhooked the pito tubes from the gateway box prior to making the switch or had they been active for the 21 years? I just unhooked mine for the first time when I winterized this past fall. As of then I was only missing the oil pressure gauge.
Bill:
The Correct Craft gauge conversion kit keeps all the original funcionality. As such, the depth gauge also displays water temp and air temp. I have to toggle between water and air temp. I generally keep it on water temp as that is really the only temp I really care about. The temp sensor that fed the gateway box (and now straight to the new gauge) is located in the raw water pick-up plumbing. The temp sensor is immediately after the ball valve and before the strainer. When I purchased the boat, one of the first things I did was remove the pitot pick-ups and tubes. I had to seal up the transom, but no big deal. I ran the boat for a season without the pitots and speedometer. The boat came with "factory" paddlewheel Perfect Pass. So, I used the PP gauge as the speedometer. The gauges never failed. The gateway box seemed to be fine. I sold the gateway box and all the gauges as a package deal. That helped offset the cost of the gauge upgrade kit.
fanofccfan
I saw your post on PN after I asked here! Got my answer. Thanks
