  New Posts New Posts RSS Feed - PCM Throttle Linkage
NeilMcG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Topic: PCM Throttle Linkage
    Posted: January-26-2025 at 4:47pm
78 Nautique w/351 and velvet 1:1
Done with the engine rebuild and installation, and while the throttle and trans is connected, it's not very smooth and there's a bit of tension on the throttle.
In looking around, it seems that there may be a few different connection styles. Does anyone have any diagram or otherwise tips for connecting?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2025 at 8:17am
Hey, does this mean the engine runs now?  Rumor gas it that the engine not only turns over but it runs tooWink
You're right about there being a few different connection styles.
As a starting point, it sounds like maybe you need to .....
Take the throttle connector off at the carburetor
Put the Morse shifter in neutral
Next, move the shifter to the Forward detent position (you'll feel a click, don't move it any farther)
Now go to the throttle cable and adjust the socket connector so it easily and smoothly slides over the ball and put it on. The adjustment could be done with the threaded socket or you might have to adjust the bracket itself since you had things apart and parts were mixed between a couple of engines.
Now, try shifting between Forward, Neutral and Reverse and see if it's smooth
Here's a picture of the typical throttle hookup on a PCM 351. It's a good picture, but the return spring is hooked up wrong and should be hooked up where the yellow arrows are pointing. The picture shows it right in the back but it should be at the bottom of the carburetor linkage as the front arrow shows so that it always wants to pull the butterflies in the closed direction> There can be variations on the spring mounting points but you always want that pull in the closed direction
You can also see in the picture, how the bracket can be adjusted or how the cable end can be adjusted at the threads.
Here's a picture of the bracket for the transmission shift cable. It mounts using the top left transmission to bellhousing bolt
