  New Posts New Posts RSS Feed - 1956 Collegian restoration
 Post Reply Post Reply Page    <1 78910>
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2025 at 9:09am
Looks awesome Alan. Get it done before GL Wink
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
pjsmoreno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2025 at 12:12pm
Wow....very impressive!!!
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2025 at 10:13pm
So I’m waiting for my seam caulking to set up so I can get back to varnishing and I don’t have the block back from the machine shop yet so I decided to do something completely different today.
This boat has a lot of solid backed rubrail trim on it.  It is  chrome plated bronze and was pretty beat up and all needed to be rechromed.  Problem is I couldn’t find anyone that could handle 12’ lengths.  My only option was to cut everything down to 6’ pieces and I just didn’t want to do that.  Plus my chrome guy wanted $100 per 6’ piece to rechrome, that would have been about 16 pieces which just sounded outrageous.
I ended up finding a supplier in Michigan that could get me polished stainless steel rubrail pre drilled and countersunk for less than half the cost of the rechrome.  Problem is I would have to learn how bend it around the bow and rear rubrails.  Once again YouTube came to my rescue and I gave it a shot today.
First i needed to make a buck in the radius of the rails out of wood.  I then lined it with 1/8” steel to protect the wood from the torch while heating the stainless.  Once it got red hot it actually formed around the buck fairly easily.  Then I rounded the ends and polished them and the bends to get the scorching out.   This was actually much easier than i thought it would be and the stainless looks very close to chrome so I’m very happy with it.
Test fitted everything and then put it aside ready to install when varnish is complete.it will all get a final run across the buffing wheel before install.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2025 at 5:12am
Exactly what I use YouTube for... Learning. (Either that or watch skilled craftsmen build things).
The famous proverb "you learn something every day" at work.
And they really look the part Alan.
In the end you can call it a small upgrade from the chromed ones (even if Pete is gonna whine about it not being original LOL ).
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2025 at 7:50pm
 Stainless looks very nice !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2025 at 8:21pm
Well I guess we won't be putting any refrigerator magnets on Alan's rub rail ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2025 at 9:09am
Awesome as usual!  Of the many stainless products available, one of the best (esp. on new ss) is Nevr-Dull polishing 'wad'. Easy to use and producing near-chrome lustre.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2025 at 8:50am
Perfectamundo (which is "good job kid" in italian) every time tried to clamp and bend it came out garbaggio ( which is italian for "the trash") did you re heat the metal after the bend was complete or is that not neccessary in this case?
Could you attach a link to the stainless rubrail supplier along with method and products you used to polish?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2025 at 11:29am
Used a torch with map gas, heat til cherry red where you want it to bend.  Once it’s red it will do whatever you want it to,just need to be patient and wait until it’s ready.
No need to reheat after unless you’re trying to fix a kink, I had one that I used a brass mallet to fix but it went back into shape very nicely.
Polisher is a harbor freight bench mount and green polishing bar.  The green bar is for hard metals like stainless.  To shape the ends i used a hand held grinder with an 80 grit flap disk then a metal file and finally 120 grit sandpaper on a random orbit sander.  From that right to the polisher.   It takes about 10 minutes from start to finish to round over and Polish an end.
Supplier ishttp://marineind.net/    Problem is shipping cost which  was actually more than the cost of the trim.  They are only 5 hours from me so we did a road trip and picked it up.   They have a facility in TN as well as MI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2025 at 3:05pm
Thanks, good instructions. 10 minutes see that would take me the whole day. I have a bunch of those polishing bars from hf, polishing anything specially metal has always been lack luster for me and every tool i got scratches the material leaving everypiece sub par
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2025 at 8:11am
So not only are you a Master Carpenter but a pretty damn good Sheet Metal Man. Approve Retirement is treating you well. I love Harbor Freight for cheap tools at low low prices that you're only gonna use once or once in a blue moon.The $60 buffer I bought has buffed my 3  boats twice and a bad oxidized neighbors 88'. "She's a Beaut Alan!"
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: February-12-2025 at 9:03am
Unless you have a brass magnet, the stainless is same same as original. To quote Hollywood, stainless is solider.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-12-2025 at 9:45am
Another plus for the stainless is if it gets scuffed or scrathed you can just pull it off the boat and buff it right back.  Win win.
Ps. Update,  I am wet sanding the final coat of varnish.
Pss. I hate wet sanding Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: February-12-2025 at 3:34pm
You’re already a fabricator and the skills just keep getting better! Seems you already been down this road before of thinking outside the box.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2025 at 7:27pm
Wow! Incredible work and attention to detail. Amazing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2025 at 5:43pm
Final varnish coat #17 went on, thought I would try to contain the dust by building a temporary booth.   Worked ok but varnish take so long to loose its tack that the finish was still full of dust.  I was trying to avoid wet sanding and buffing but that didn’t work out
Started wet sanding with 1500 but it wasn’t cutting so had to back down to 1000, then 1500 and 2000.  Exhausting.   After that I cut it with a 3m light compound and finally a polishing compound.   That was 3 days worth of work and I still have the engine hatch to finish up but the results are impressive.
Today I decided to give my arms, hands and shoulders a break so I installed some rubrail.  Nice to see some real positive results.
Tomorrow the plan is to finish the engine hatch then the next step would be to paint the stripes and start installing deck hardware.
Sorry no matter how I flip that image it displays like this. Confused
Still waiting for the cut water and transom bands to come in but I think  they are close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2025 at 7:28pm
Here ya' go  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2025 at 8:44pm
Here ya' go  Wink
Thanks Keno,  I fiddled with that long enough figured someone would save me.
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2025 at 8:20am
Looks amazing. DEEEP....
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2025 at 8:32am
Beautiful Job !!!!!Thumbs Up
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2025 at 9:31am
Everything about that is gorgeous, the two colors, white outline, stripes ... truly a work of art.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2025 at 10:11pm
OMG !!! Alan,   It's not a Rolls Royce.   Oh well I guess it is now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:14am
 Dead Having worked on Rolls Royce Engines for the last 15 years I can assure you firsthand, .... they are a  Censored POS.
 Calling "What's her Name" a RR is an insult!   TongueWink
She sure is Purty Alan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:02am
I remember when my dad re-varnish the Chris-Craft inboard he had. I know he put at least 5 layers on. He kept telling me “Don’t touch!” while I was watching him and walking around the boat.  I was either eight or nine at the time. Do recall him sanding and buffing it out before it was dropped back into the water. Today I understand why we put many layers of finish on wood. This is going to be a keeper if it was me! This is beautiful!
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:32am
     Sorry Tim,   I probably meant to say the Packard / Merlin version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:57am
I thought Soul Mate was a keeper too. I think Alan is addicted to the craft for the delight self and of us all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:09am
Well guess it’s time to reveal the name,  Timbob’s been prying for too long.  I’ve been going round in circles with this one.  Nothing romantic or in memorial of
She will simply be referred to as  “Goulash”
This boat has very little originality left and it is assembled using lots of leftover parts and supplies from two previous builds,  the engine is the repower from #1,  the wheel is from a 1956 Thunderbird, interior is something from my imagination, etc, etc
Miriam Webster defines Goulash as “ a mixture of heterogeneous elements: A Jumble.   So there you go, it’s just goulash.
There is also the cynical side of me while at boat shows surrounded by 6 figure Filet Mignon boats I’ll be sitting in our old Correct Craft Goulash..The poor man’s meal.   Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:46am
Goulash....I Love it....I think most of us have the cynical side of life with these old boats.  I can not begin to describe the amount of attention a modest $5000 Red Marauder garners amongst the six figure tugs floating right beside.  Alan, I can not begin to imagine the $$$$ and time you have in this absolute stunner but "Goulash" will turn more heads and create more conversation than "Air Force One"!!!!  Thanks for the efforts and thanks for sharing the journey so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:33pm
Got the stripes painted using a pinstriping roller,  good thing I gave up coffee so the hands were steady.  Only a few touch ups with the brush were needed.  Came out decent, I’ve seen better and worse jobs so I’m good with it.
Lot of respect for people that do this professionally,  there’s a fine line between looking good and making a mess of things.  I’m in the middle somewhere.
Started installing some feel good pieces but realized I’m rushing things as the varnish has not really hardened yet, it’s very delicate right now so it’s easy to scuff.  Needs some time in the warmth and sun so I’m going to tackle the exhaust pipe holes and gas tank installation next and just let the finish cure.
I’m thinking this would be a good lid for my casket when I check out.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: Today at 4:30am
This made me smile so hard my cheeks hurt Big smile
I would argue that you are quite North of that middle.
