Spark Plug Selection |
Author | ||||||||||||||||||||||||||||||||||||||||||||
Otto Throttle ![]() Senior Member ![]() ![]() Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 400 |
![]() ![]() ![]() ![]() ![]() Posted: March-01-2025 at 10:41am |
Ok I don't mean to "Spark" any controversy but here goes....
Spark Plugs...Mine HO, 285 HP, Carbureted (GT40 Heads) calls for the WL764s. I have seed both the standard, copper, and platinum electrode versions....I am still running the factory original plugs, but I want a spare set...just in case. What brand and electrode are you running out there! Thanks in advance! Otto
Otto
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21197 |
Standard is copper and the best conductor- should offer the best performance and lowest price. The advantage of the platinum and iridium tips are longevity, you’re usually best served running the copper and replacing them more often.
Thank you!!!
Otto
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
Some have indicated that the Autolite 764 is discontinued. They can still be found, especially on the internet.
The Autolite 104 is the replacement plug for the 764 and is basically the same plug -- 104 has full threads on the body and the 764 is threaded halfway. Either will work. (GT-40 or GT-40P heads) JQ
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11184 |
One thing to keep in mind here is that
A copper plug typically has a nickel center electrode with a small diameter copper wire buried in the middle of the center electrode A platinum plug has that same small diameter copper wire buried in the middle of the platinum tipped center electrode An iridium plug has that same small diameter copper wire buried in the middle of the iridium tipped center electrode You can't visually look at any spark plug and see any copper. (unless you destroy the plug to get at look at it) And like mentioned earlier, the copper core standard plug will be just fine in your engine Otto And Otto..... you should probably change those plugs a little more often than every 27 years or so.
What is the difference between full threads or half threads? Does one run cooler than another?
Yea I know… my cousin has the same boat except an 1998, and he has never changed plugs either! He has 400 hours on his and I have 500 on mine. I was thinking when changing them to soak the threads with kroloil for a few days….. That being said we are checking driveshaft alignment and repacking the rudder and drive shafts this spring! Any tips on those projects? |
Otto
Also what do the prefix’s mean before the number…. WL or AR… what if there are no prefixes?
Otto
![]() Full Threads vs. Half Threads The thread length shouldn't affect anything. I believe that you are thinking about the plug's heat rating. Per the Autolite catalog, both the 764 and 104 plugs have a heat rating of 9. I ran both the 764 and 104 in my 1994 and 2001 boats -- both with the High Performance Ford 351W. Just for giggles, I change spark plugs every couple of years. My OCD lizard brain... Anyway, I would pull the plugs and they both looked and performed the same. JQ
Autolite CopperSpark Plug - 764
Spark Plug - 104 Specifications:
Autolite spark plug prefix list:
XP = Iridium AI = Ultra Iridium AP = Platinum APP = Double Platinum JQ |
Jonny didn't exactly answer this question for you If you had an AR764 for example, that's an Autolite rrrrrracing plug. You dion't need any of those. You won't find a plug with WL764 stamped on it anywhere......but if you look at White Lake Marine's nautiqueparts.com you'll see them selling a plug with their part number of WL 764. It's the same Autolite 764 that you can buy anywhere else. No difference in the plug itself....none at all. A regular ol' copper core 764 has no prefix in front of it. It just says Autolite 764 on the plug So if you had a WL764 in your hand and read the stamping it would say Autolite 764 There's plenty of mumbo jumbo out there from all the spark plug outfits to keep you confused ![]() |
I figured that was the case, I guess with the more confusion, get people to buy the wrong stuff the first time around, and then after they come to a place like this, they find out what they really need! I will go to my local car parts store And support something local!
Thank you for clearing that up, I know spark plugs make a difference. My Evan tech has indexed plugs. That’s a whole Nother topic. This place is an underrated source of information! Thank you everybody |
Otto
One last thing and I think we covered it… resistor vs non resistor plugs… pros, cons, and and applications?
Otto
Resistor or suppressor type plugs are what you want.
They both do basically the same thing and minimize RFI
The 764 are suppressor The 104 are resistor Non resistor sounds sexier and more powerful.......but you don't want them, especially with any electronics on the boat. Now your mission is to go buy some 764 or 104 plugs or it it makes you feel better you could waste, I mean spend a little more for AP 764 or AP 104 for a somewhat longer plug life ![]() |
