Gelcoat |
CraigM ![]() Newbie ![]() Joined: January-16-2019 Location: Spokane, WA Status: Offline Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: April-02-2025 at 9:01pm |
Hey Everyone,
I have a couple questions regarding gelcoat restoration and painting with gelcoat. I have a white 1972 Skier. 1. Is the original white color on the Skier hull a pure white you would buy from any gelcoat seller? I have recently painted the floor gelcoat white and it looks to be a brighter white than the hull and bottom. Is my hull just faded? The original color seems to be a creme color or off- white. Are people coloring matching? 2. How have other Correct Craft owners restored their boat's hull gelcoat? I brought my boat to a fiberglass company and he basically stated that the cost would be thousands and thousands of dollars and not even worth it. The hull on my boat isn't too bad. There are 4-6 spots with spider cracks, some good scratches, and the hull needs a good polishing/waxing. 3. What are the goals of most Correct Craft owners in terms of restoring the hull? 4. Do people paint their boats with something other than gelcoat? Thanks for the advice and suggestions! |
Craig P
samudj01 ![]() Gold Member ![]() ![]() Joined: March-10-2009 Location: NC Status: Offline Points: 984 |
I have done two boats...one was a 78 Ski Tique with white gel and yellow/black lettering. It had a few scratches and some minor spiders and we compounded and polished and the white came out well. It is not perfect but good looking post-work. Some folks have had to sand too but more than likely for white, you can heavy duty compound, polish and wax and be happy. Matching white is tough! So I would think twice before grinding spiders and scratches unless they are not seen (on the hull bottom). Sanding a scratch and then doing the above process gets it looking good from 5 feet. See my thread http://www.correctcraftfan.com/forum/forum_posts.asp?TID=40614&title=new-to-me-78-tique for pics and discussion. Your hull is prob faded but also, the white used by factory was not bright white. It was a little off. Others can chime in on the color. We tried to match in some places and we had to tint the white with some yellow I recall.
The other boat was orange and the gel didn't cooperate. We did a full re-gel of the hull. Lots of work to sand down and $ to re-gel and then lots of work to polish. We compounded and polished the white top deck and doghouse, and again, the white really came back well. I would try that first for sure. All products and steps used are detailed in the threads. Skier thread: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=43078&title=new-to-me-72-skier |
pjsmoreno ![]() Senior Member ![]() Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 200 |
Yes, gel coat repairs are costly if you don’t do the work
yourself. When I brought my ’89, it too had that creme off- white color. It
wasn’t till the aquamarine strip started turning to a dirty green color is when I
started removing the oxidation. That’s when
I started seeing my boat was actually white. But we are talking about two different
styles and years apart of boats from each other. Took a lot of hours to restore
the gel coat but I’m glad I did it. I dealt with a couple of scratches. I
filled them in and was able to match to the original. Spider cracks I did not
have to dealt with so I really can’t give you any advice on that. |
