spark plug gap |
bsucics
Senior Member Joined: July-18-2006 Location: United States Status: Offline Points: 109 |
Posted: April-29-2007 at 4:10pm |
Changing plugs for the first time. The plugs that I've pulled have a 30 gap. I do not have the original manual, but from the information that I've read here, I had set the gap to 34. Can anyone verify this? Thanks!
nuttyskier2002
What engine do you have? Year? CID? Ford or Chevy? Need some additional info.
bsucics
89 sn 2001 w/F351 - pulled out motorcraft plugs and replaced with autolite 24's
bsucics
Found .035 in the engine manual posted in the reference section, so I guess that's the answer. Should I expect to see a difference in anything since previous plugs were gapped at .030? Thanks
nuttyskier2002
None that you will really be able to tell.
83_2001
Newbie Joined: August-15-2006 Location: United States Status: Offline Points: 27 |
Just replaced mine, the plugs I pulled were at .045! I called SkiDim just to double check the .035. I haven't dropped her in yet, but after starting her up with the fake a lake over the wknd she sure did sound like she idling quite a bit smoother. Just need to finish up my teak platform and we are good to go!
swifty
Newbie Joined: April-27-2007 Location: United States Status: Offline Points: 15 |
Does this gapping go for a 1976 302? Thanks for your help
acpskitique
Groupie Joined: April-10-2007 Location: United States Status: Offline Points: 51 |
Yes, .035 is correct. The Autolite 24's a got for mine were almost dead on out of the box.
'76 Ski Tique 302PCM
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5800 |
Hey guys,
There are downloadable PCM manuals in the reference section of the site. They are loaded with info on your engines and tranny. I've read mine from cover to cover and you'll amazed at the little things you can pickup.I rebuilt my 351 with info and specs entirely from these manuals, I think it's good reading and would probably answer a lot of questions in maintaining a properly running rig. Enjoy |
