  New Posts New Posts RSS Feed - 80 Ski Throttle
80 Ski Throttle
NautiSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiSki Quote  Post ReplyReply Direct Link To This Post Topic: 80 Ski Throttle
    Posted: February-28-2005 at 4:12pm
Help a new owner out and explain the purpose for the small round adjustment piece located just in front of the throttle lever which is actually part of the housing. Is it the choke and if so is the engine choked if pulled outward?
NautiSki
1980 Ski Nautique
Troy White
817-266-0711
Grapevine, Texas
hotwife View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotwife Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2005 at 4:17pm
its for taking the engine in and out of gear. Should not start if button is in. In - enagages the drive. Out should be out of gear
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2005 at 5:21pm
Actually, I think the engine will start with the button/knob in either position so long as the throttle is closed (i.e. lever straight up). Pull the button/knob out for neutral, then you can rev the engine in neutral by moving the throttle lever back (towards the stern).
When starting a cold engine, you should pull the knob out, pump the throttle once or twice. Move the throttle lever to straight up (neutral) position and start the engine while the knob is still out (neutral). This will allow feathering of the throttle to keep the engine running if the choke is not properly adjusted, etc.
nautique frk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique frk Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2005 at 1:15am
David F is Right !!!!!
