oil pressure too high? |
bsucics
Senior Member Joined: July-18-2006 Location: United States Status: Offline Points: 109 |
Posted: May-07-2007 at 10:01pm |
Changed the oil for the first time last fall (changed from unknown to Valv 10w30. Noticed when fogging the engine the pressure was significantly higher (I think it used to be 40 psi at idle). Fast forward to spring, I was running the engine this evening. At idle, I'm now showing 60 psi. Seems extremely high for such low rpms. No known problems, but I'll have it on the water next weekend. Anything to look for, or be cautious of? Thanks
MaddMarxx
It should come down when the oil warms up!!
Dan, Are you sure that the gauge and sender are ok? I just went through this about a month ago and it turned out to be a bad sender.
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
Noticed the same with on '05 Excalibur. Changed the oil and for about 2 minutes had an easy 20 psi higher at idle or running rpm's. After she was running on the water, the oil warmed up and now the pressure is the same as before the oil change.
I think this equates to the fact that we left the old oil in for too long! Probably need to increase the frequency of the oil changes. |
bsucics
Thanks! I can't confirm that the gauge and sender are ok - I'll have to read up in the forums on that topic. I'll get it on the water this weekend and see what happens when its up to temp.
ok this is pretty stupid stuff here, change the oil more often so the pressure is up, changed it and now higher pressure.
the oil pressure will always be at least 10-20 psi higher when the oil is cold, the weight/grade or brand really has no effect on the pressure. If the motor is low on oil then the pressure can read lower than normal because it's sucking air. Use a quality filter, change it regularly, check the level regularly and it will be consistant within 5 psi. |
