  New Posts New Posts RSS Feed - Transmission squeal
Transmission squeal
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2007 at 11:56am
Originally posted by David F David F wrote:
This should get people blood flowing: When I had my Martinique with the CC drive on trailer, I used to load the boat by driving on the trailer and leave the engine running (abit above idle speed) AND in forward gear. My buddy (or wife) would then pull the boat/trailer out of the water. Once the prop cleared the water, I would shut the engine off. Kept the bow of the boat tight against the crash pads and by apply a bit of rudder, I could keep the stern of the boat centered between the posts.
Never burned up an impellar....NEVER. Have at me boys.
Did this on our 58 Trojan for 20 years. BKH
Livin' the Dream
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2007 at 10:46pm
Wow- this thread got a lot of mileage for a loose belt. My buddy's MC has old worn out belts and it squeels every time he fires it up in the water.
replace/ tighten the belts and if that doesn't solve the problem, you've at least removed one variable from your troubleshooting list.
Good Luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 8:31am
I actually thoght it was a mouse on the boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 8:57am
Good Luck
I thought that MC's always squeel! Sort of like a stuck pig!
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 9:03am
Pete,that is like saying your best friends old lady is not just ugly but she is fat too.
We have to love them all,not everyone CAN OWN A C/C..........boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 9:35am
mopeds...fun to ride
gigem75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gigem75 Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2008 at 9:15pm
We're going to have to get our stories straight. In another thread it was stated that the water the the cylinders probably came from him not draining the engine before he pulled the heads. If that is correct then there should be water at the rwp which would provide the lubrication for a second or two of running. If not, the debate continues....
I tend to go with that if you understand what is happening when the engine is running you won't let it run long enough to do any harm. That's why some have never had a problem. It's the people who have no clue as to what is going on down there that imho tend to have all sorts of problems with their machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2008 at 10:43pm
If you want to see if it turns over in your driveway, pop the cap off of the coil.
My guess is that your prop is turning when you start it in nuetral, and the shaft is rubbing on the cutlass bearing.
