  New Posts New Posts RSS Feed - Floor Repair
Floor Repair
wakeboarderdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboarderdave Quote  Post ReplyReply Direct Link To This Post Topic: Floor Repair
    Posted: May-25-2007 at 1:06pm
We just recently purchased a 88 Nauti 2001. The boat runs like a champ. The only problem is that the floor under the drivers seat and passenger seats is rotted out. It gives when you walk over it and the bolts that hold the drivers seat have stripped out. How can I go about spot repairing this area? The rest of the boat floor is solid.
Suthoff all the good times we had together will never be forgotten and I wish we could have been closer over the past few years. Watch over us all!
Mark Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Mel Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 4:03pm
Do a search for 'floor' and 'stringer' pleanty of information here.
1978 Nautique
FBook - www.facebook.com/charliedontsurfct
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 6:15pm
wakeboarderdave,
Are you shure the rest of the floor is solid, how are the stringers? Did you check them for rot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboarderdave Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2007 at 11:05pm
To check for stringer rot you just have to tighten the bolts that go into them correct? And if they free spin and don't tighten, then they are rotten, correct?
I did do a search and really didn't understand anything on it. So I figured someone might chime in with some useful information.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2007 at 12:26am
Dave,
The boat has a section of plywood in the fllor from the motor box forward about three feet. It is under a layer of fiberglass, but it is common for the the plywood to rot in that section. I'm not positive why they put ply in that section, but the common theory is the it is so the seats can be screwed down more securely. Over time, water gets in through the screw holes and elsewhere. If you remove the seats and peel up the carpets, you should be able to tell where the ply section is.
Once that ply section starts rotting, it is likely that the stringers have begun to rot as well, particularly on a 20 years old boat. You may get lucky.
One way of determining if you have bad stringers is to put a wrench to the lag bolts which hold the aluminum motor bracket to the two main stringers. If they spin freely, then you know you have a problem. If not, you
may still have a problem below the spungy section of floor. On my boat, I could look under the front section of floor from the bilge and see that the stringers had rotted around the cooler area.
If you do a search on "SkiBum", you will see two threads that Bill "SkiBum" started regarding stringer repair and gel coat repair. These are great threads because Bill has posted about 100 progress pictures. From Bill's photos, you get a great visual of how your boat is put together.
Hope this helps.
BKH
Livin' the Dream
damer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote damer Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2007 at 8:31pm
What if your not that handy. What would you expect to pay someone to do the floor and stringers?
Party like Normal!
leo0648 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leo0648 Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2007 at 1:18am
I know a guy in TN who will do floor and stringers for $2500. $3100 after tax.
