Got pipes? |
Post Reply | Page 123 4> |
Posted: May-30-2007 at 11:38am |
Those following along with my top end issues have already seen these pics, but Ill share them here for everyone else.
My dual exhaust project is done. For those unfamiliar, Correct Craft started installing 2-in, 1-out mufflers in 1989. That means that with the exception of a very few boats (502 Pythons boats, for example) all CC's since then have had a single exhaust outlet. The biggest trick on this project was creating room for a second pipe, with an outlet symmetrical to the original. On all '89+ boats, the exhaust is routed between the primary stringers instead of outside of them. That meant that a second pipe runs very close to the centerline of the boat- right through where the rudder arm used to swing. The picture below isnt from my boat (possibly Darrel's?) but it shows how the stock exhaust and rudder arm looked (though mine was run on the opposite side): On the motor side, I matched the 3.5" header outlets to a section of 3.5" SS piping that brought the exhaust to the floor. Theyre not symmetrical, as each side had its own obstacles- water intake hardware, blower lines, etc. I had a custom exhaust place build the pipes for me, and I had them ceramic coated to match the Hi-teks. The tips are 4" polished SS with internal flappers. I had the reducers welded to the tips and a section of pipe added to that. This gave me a little extra clearance with the rudder arm and gave me 2 straight shots back with the reinforced hardwall hose. I could have gone SS all the way back, but the hose provides support (it sits on the hull) and absorbs vibration. It also keeps the exhaust modular should it need to be disassembled. While everything was apart, I ran all new cooling hoses as well as fuel lines, and replaced the steering cable. The boat should now be JBear approved. It still has the characteristic whine from the 1.23 tranny, but compared to the exhaust its almost unnoticeable. Slip-in style silencers/mufflers are coming in the near future. As far as I know, this is the first boat to be converted like this. There are a very small handful of boats that were converted either by the factory or dealerships- but the ones I could find all had 2 new holes cut closer to the inside of the stringers. The original hole (if there was one) was either plugged or re-glassed. If nothing else, its different. |
boat dr
Tim, there is only two people that would tackle that job;
TRBenj & The Boat Doctor..... And for the same reason; Did not know any BETTER.ha ha looks awsome tim, proud of the finished product and the part I played in it.................billy |
all show and no go....like the Boat docs,
maybe we should re-name the site "trailer queens only" on the serious side i see many signs of perfection and I commend you |
backfoot100
Tim, looks awesome. I couldn't have done any better myself. Bet it does sound great too!!!!
Eddie |
Tim, It sure is looking good. It does look like alot of "customizing" with the plumbing and the steering but I'm sure the results will be worth it. You've got over 6 weeks before GL so that's plenty of time to fine tune the project. Looking forward to seeing it.
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
Boy does that look sweet. All I can hear though is my wife saying "you want to do what?"
Darrel
Senior Member Joined: June-16-2004 Location: United States Status: Offline Points: 340 |
That is a lot of fabrication work! And worth it based on looks alone, very trick. The stainless drop pipes are so much cleaner looking and give you more room than the invertaflo. Love the end tips too, makes it look like the hotrod that it is! I was hoping that you would explain in more detail when looking at the pics in your engine post. Thanks and good luck on the fine tuning.
boat dr
Eric, if I was you I would not be bashing nor talking poo poo about our boats being T/Queens.I know for a fact you have some less than stock parts on your boat,need I tell the whole story .
I see you have not posted any pics of your new ride, how about a shot of the helm, complete w/steering wheel and control box.You did say it was a binacle mount shifter ,did you not.Have you made any mods to it? With that being said I hope we don't have to share with the fellow members ,what is in the box I shipped.Even more so what parts that they will replace. Am I coming in loud and clear Mr. Levine??????????boat dr Sender of parts to make you boat look like a white man owns it..... |
you getting any work done today B.D.?
insults are a form of flatery |
M3Fan
I feel honored to have gotten some sneak peeks at this setup before it was "made public" so I've said this before and it bears repeating- congrats on an AWESOME project. Can't wait to see it this summer.
insults are a form of flattery, oh by the way its LaVine |
boat dr
Eric, is that a capital "v" like Vice Grips.Don't punch my buttons Eric,or the newest post on this site will be:
And Now The Rest Of The Story..... |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5781 |
Looks awesome Tim, great craftsmanship. I do have a funny feeling you're no where near done with the mods though. Seems there are quite a few here with that afliction. Sure is rewarding along the way though isn't it.
Barracuda
Well done Tim! Can't wait to see it this summer.
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
WOW!! Awesome job, i think those stainless drop pipes are my favorite.
Well done!! Nate |
todicus
Senior Member Joined: July-10-2006 Location: Napa, Ca Status: Offline Points: 493 |
I'm jealous......... I alway's have wanted my 95 to sound like my previous 88. You have definitley broken some new ground on your boat. It's a "one off" original, that many will copy in the future.
Well done !! |
quinner
Tim,
That is so awesome and it must sound even better than it looks. Nice Work! |
JMurph
Gold Member Joined: January-06-2006 Location: Maryland/NC Status: Offline Points: 738 |
Tim,
I will no longer post any pictures of my 79. I am embarrassed to say that I think your engine well and engine are cleaner than most of the spaces in my boat. You are quite the person of detail. Nice job. It sure is beautiful and I'm sure it sounds even better than it looks. -John |
reidp
JMurph, I know what you mean. I put the Hi-Teks on mine and the rest of my exhaust pipes/hoses look like a patch quilt compared to this thing of Tim's. I'm just gonna 'glass my engine box shut until after Green Lake. Tim, if I was a boating GIRL, I'd be all over you, cause you can obviously do magic.
6strings
Senior Member Joined: August-05-2004 Location: Indiana Status: Offline Points: 218 |
Tim,
Very nice. What a clean and sleek look. I agree with the rest, I'd be embarassed to open my engine box! Two questions, as I'm not familiar with the "newer" models: What are the two things on either side of the pipes that look like vent scoops? Also, I've never seen the copper line going from the stern to the rudder box. Is that for cooling/lubrication? You're gonna have fun with that boat! |
nates78ski
The two "scoops" on either side of the pipes are the lifting rings, during the sloped transom time they took the single lifting ring at the top, replaced it with a tow point & moved the lifting rings to below the swim platform. I believe this to be true, but i also may be talking out of my ass...who knows?
Nate |
Tim, As I mentioned previously, it does look good however I do have one concern. I know it was a tight fit and wish there was a better way for you to route the steering but your modified steering arm will put a lot of overhung loading forces on the stuffing box and rudder shaft. The original arm was bent downward not so much for clearance but to primarily equalize side loading on the box. I can't really tell from the picture but is there enough clearence to get the arm bent downward so it will go under the port exhaust pipe?
67nautique312
Gold Member Joined: June-23-2004 Location: United States Status: Offline Points: 883 |
Tim,
you da man!! See ya at Green Lake!! |
67 Riviera 68 barracuda 1971 Ski Nautique Promo 86 Silver Nautique 1995 Ski Nautique |
M3Fan
Those plastic covers keep exhaust from bubbling up through the lifting ring holes in the swim platform. CC was WAY AHEAD of the industry in controlling exhaust gasses and getting them away from passengers. Heck, here we are 17 years later and the other brands are finally putting exhaust warning stickers on their boats. Note the rubber sealing strip as well that goes all the way across the transom where the platform meets the boat. That copper line is a custom-installed remote grease fitting for greasing the rudder box. Some serious slalom drivers like greasing the rudder box, but I don't see a need for it. |
nates78ski
I can't stop staring at that exhaust... i think this might be my new favorite thread. mmmm
Nate |
6strings
Okay...grease fitting and lifting rings! Now I get it. Thanks guys. It helps to ask questions here so as not to appear ignorant in person!
I can't see the pix but steering arm moment is negligible compared to the forces the bushing sees from the rudder underneath. The rudder effort is neutralized by material forward of the pivot, but the total side force it develops is significant and a lot higher than one can produce with the sterring mechanism.
JR_VIC
Senior Member Joined: June-05-2006 Location: United States Status: Offline Points: 175 |
Tim,
I just found this thread and looked at all the pics and man what a fabulous job. That must have been quite an undertaking. I thought my project was tough but at least I had a shop manual to follow along and guide me. How long did it take you from start to finish? How hard it would it be to install just one of those polished exhaust tips? Great Job!!! Thanks! |
"That's not a Snow Cone that's my Ring!"
Wow, lots of nice comments to come back to after my long weekend- thanks everyone!
Eric, trust me- shes no trailer queen! These pics are a few weeks old- I meant to take a bunch over Memorial Day weekend but I was too busy hot lapping the lake. It does sound good- at least to me. Our lake is pretty small so Im not sure my neighbors will agree, especially when it comes time for some early morning barefoot runs this summer. Jeff, total time invested with the project wasnt too bad, actually. Doing the floor last year was much worse. There were about 3 weekends worth of my labor, but it did take a lot of planning- sourcing parts, hardware, etc. Plus the time spent at the exhaust place, machine shop and coater's. About 6 weeks start to finish. Cost was a lot more than expected, but that somehow always seems to happen. Installing a single angled tip on your boat wouldnt be hard- lots of places sell the 4" parts (mine are Eddie Marine). The mounting holes likely wont line up (mine used 3 bolts instead of 4), but I sealed everything with Boat Life Caulk. |
I want to bump this up since JBear's back. He made it perfectly clear that the stock exhaust note on these boats was unacceptable.
Im still tuning, but performance is improving. Carpet and interior will slow progress on the motor in the coming weeks, but I should be back on the water before the 4th of July. New pics: |
