  New Posts New Posts RSS Feed - MY HOLLY IS JUNK
MY HOLLY IS JUNK
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Topic: MY HOLLY IS JUNK
    Posted: March-09-2005 at 4:56pm
who has the best price on a new [not a rebuild]holly carb for my 210 interceptor.66polyhead says i should maybe use a 550.and a wedge plate.
how do i move this post down one to parts wanted ?
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2005 at 5:19pm
Summit racing will have the best price for new marine carbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2005 at 5:30pm
thanks 79 i'll look em up on the net .
does a holly 500 or 550 sound about right 4 that engine ?
66polyhead has the old 1 and i'm not sure what it was. other than fuel leaking junk !
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2005 at 6:28pm
Maybe a 450 cfm is correct. I know the listings go like 450 600 750 850 1050. If you have a catolog it is easier than using the web page. With 210 cubic in motor a 450cfm carb should be more than enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2005 at 6:55pm
i didn't find a marine carb at summit.but discount inboard marine says a 4160 would work. does that sound right ? $579 ouch!
i want to be sure b-4 i order anything.
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2005 at 7:36pm
Summit has them for under $400
4160 is the model and not the size carb a 4160 comes in 450cfm, 600cfm, 750cfm and so on. Have Summit send you a catolog or search holley marine carburator.
66polyhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2005 at 1:14am
Kenny, checked the carb. tonight. It is a list 1850-2, that no. according to Holley, is a 4160 style, 600 c.f.m.. With a primary main jet 122-66, and a secondary main jet 134-9. It is a vacuum secondary, with manual choke, no "J" tubes!
Holley marine carbs
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2005 at 2:34pm
Kenny,
That Holley that you pawned off on Wallace definitely wasn't the original. Was it on the green SS? The Interceptors like mine, came with an Autolite carb. I've got one that came off mine, that I'm sure would need a rebuild that you're welcome to. Depending on the year, they used both style Autolites, the square shaped one or the elongated Holley shape. But if you're going with the new Holley, BC is correct in the 450 CFM size for a 289-302, which unfortunately I guess, because of less popularity, typically costs more than the 600. And so did you end up buying the green and light blue Mustangs? I dug up the photos just the other day that you sent me way back when.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2005 at 3:13pm
yes reid i bought them both.
the holley is for the green 68,i found a new [marine]600cfm for 400bucks.the 450 was well over $500 almost 600.it should work ok for now.
if my new pole barn is built on time i want to come down for the NCNOA in may.sandy will be off work for two months and would be a good time for a road trip for us.i'll call you.
kenny g
Dampilot View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dampilot Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2005 at 1:15am
There's a ton of marine holleys on Ebay
nates78ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2005 at 8:51am
Unless you are a fanatic on an original carb I suggest an Edelbrock marine carb with electric choke. Tuning & maintainence on an this unit is simple. On 260-289 engines 600cfm is no problem.You can find these carbs @Jegs for $300.00.
Nathan
My '78 Ski Nautique
BOBM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BOBM Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2005 at 1:22pm
The chrysler 318 polyshpere motor, 210 hp
in a 66 boat originally had a carter afb-3213s.
600 cfm. Edelbrock make a good replacement, but
you might try a professional carburetor rebuild
shop, for less than 1/3 the money, and they
should be able to tell you before hand if it
is rebuildable. thats the route im taking
with mine.If your motor is really a poly?
BobM
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2005 at 2:36pm
I had a holley 500 cfm (2 bl) on my '66 Mustang and it didn't perform better, it just used alot more gas. I switched to a holley 350 and it performs better, liked it did with the stock carb which I think is a 325.
Tim D
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2005 at 6:05pm
There is a new Holley 450CFM 4V on Ebay now for $469.95.
I'm pretty happy with my 450. I had it on the river this morning and my 289 ran right up to 5300RPM pretty quickly. I don't really want to go higher than that.
IMHO, the 450 will do a better job of metering fuel at low (towing) speeds. I have nothing to base this on however.
chris View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2005 at 1:43am
you might want to check out this site. the seem pretty cheap. http://www.nationalcarburetors.com/
Chris
