  New Posts New Posts RSS Feed - Pro-Tech Ignition System
arondeau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arondeau Quote  Post ReplyReply Direct Link To This Post Topic: Pro-Tech Ignition System
    Posted: May-31-2007 at 6:59am
Good morning guys / gals. I have just completed a Pro-Tech ignition conversion and have the old (complete) Coil Pack setup. The boat was in limp-mode, so I am not sure what exactly went wrong. Not sure if the coils can be "separated" and tested, re-used etc. If anyone needs this complete kit, let me know. I have a 1993 Pro-Boss with 450 hrs. Also included will be a brand new set of 8mm wires. The wires were bought to replace the old ones, and were actually on the boat for one day before the ignition problem.
91sporty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91sporty Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2007 at 9:03pm
I think I have the same problem you had. Waere ther any other symptoms are did it run fine then go straight to limp-in mode?
pbarwick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pbarwick Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2007 at 10:27pm
I am interested - how much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote arondeau Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2007 at 3:15pm
Yes, 91 Sporty,
it ran fine then it would go into limp-mode. I am told that is what they do. As soon as the coil pack gets hot, that's it. I called Discount Inboard Marine (they are the BEST), and they told me to check a couple of sensors. I disconnected them and it did not make a difference. So I assummed it needed to be replaced. Got the kit, and my mechanic did the job for me. It's been fine. Are you still having problems?
Post Options Post Options   Thanks (0) Thanks(0)   Quote arondeau Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2007 at 3:19pm
pb,
yea, make me an offer. I do not need the parts. I have a brand new set of 8mm wires (PleasureCraft) with it. The wires were on the boat about one day (less than an hour of use). I do not need the old parts. Not sure if you can inter-change a dead coil with one of my good ones. May save you having to do the conversion. The conversion will cost you $500.00 for the kit, plus labor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91sporty Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2007 at 9:32am
Yes arondeau, still having problems but I don't think it's the coil pack itself because both sides of coil pack shut down at the same time. It might be the module. I'm assuming your module is still good but your coil pack failed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote arondeau Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2007 at 3:03pm
hey sporty,
yea, I am not sure what exactly went on my system. All I know is that it was not any of the sensors. I disconnected each one individually and tried running the boat. That's when I decided to do the conversion since it would have to be done anyhow. I have my old components if you want them. Make me an offer, and you can have a brand new set of wires with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91sporty Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2007 at 10:07pm
thanks arondeau, I'm pretty sure my module is bad. I know my coil packs are good but I ordered the conversion kit today. Tired of problems. thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote arondeau Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2007 at 6:24am
sporty,
good luck with the kit. My mechanic did the job in about 2 hours. My boat runs fine with it. Let me know how you made out.
Andy
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2007 at 7:57pm
Whats the price I'll stock the parts if price is right..
Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote arondeau Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2007 at 8:39am
Munday,
"stock the parts" on what? A new conversion kit? I paid $500.00 for my kit from Discount Inboard Marine (they are on the web). I have a "used" kit that I do not know if the good parts can be reused. I'll sell mine for $50.00 + shipping. I do not have any use for them since my conversion. I also have a brand new set of Pro-Tech 8mm wires. I paid $45.00 for them. You can have them for $25.00. I used them for about one day to diagnose the ignition problem.
Andy
sanddragnon2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sanddragnon2004 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2007 at 6:34pm
do yo ustill have the coil wires and the parts? got pics? i might be interested, what converstion are u refering too?
New nautique owner here.
ScottZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2007 at 2:42am
I have a 1992 Ski Nautique with hat same ignition system. My motor was running on 7 cylinders. I went ahead and converted the ignition system too. I have the old system I want to sell. I do not hve the plug wires though. I used them on another one of my motors. If anybody is interested, please contact me and make me an offer. It's not doing me any good and someone may be able to part it out to repair their system.
