  New Posts New Posts RSS Feed - Hose between trans cooler and raw water p
stevieh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevieh Quote  Post ReplyReply Direct Link To This Post Topic: Hose between trans cooler and raw water p
    Posted: March-08-2005 at 2:47am
I just replaced the impeller on the raw water pump on my 1978 Ski Nautique. I need to replace the hose between the transmission cooler and the pump. Does anyone know what size the hose is and where to get it? I understand that it needs to be wire reinforced. My old one was too large at the pump end and had a filler sleeve placed in it. I would like to find the correct hose. Please help.
Stevie Hutton
captan1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captan1 Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2005 at 1:02pm
Just measure across outside to outside edge of the water pump and oil cooler to make sure they are the same and there's the inside diameter of the hose you need, I think mine - a 78 Nautique is 1".
West Marine, Boaters World.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2005 at 4:15pm
Mine doesn't have wire on the inside which would rust and catch trash and the wire would break off in pieces and destroy the impellor. My hose is black on the outside and white on the inside, the white part is somewhat stiff and it keeps the raw pump from causing it to collapse.
Tim D
Bradley950 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradley950 Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2005 at 1:03am
My hose is also 1" on my 76. It is not wire reinforced the old style hose was, it seems newer hoses are just built stronger. Mine is also white on the inside. Besides there is not really that much water pressure.
                            -Brad-
Brad Miller
bradley950@yahoo.com
curbsidegold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote curbsidegold Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2005 at 2:42am
I bought some clear flexible reinforced hose on the cheap from Lowes which works fine + you can see it work. I did splice in a shutoff valve between the strainer and engine which is referenced in in my old Graymarine engine manual as optional. Does anyone know if this is a "critical" add on? What I mean is, will my boat sink if I left it parked with the valve open
sm
nms1991 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nms1991 Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2005 at 6:00pm
Which conversion is it? Commander? PCM? The PCM conversion uses 1"inside diameter and the Commander uses 1 1/4 hose and the pump has 1' inlet that they used a peice of 1' clear hose to compensate for the differance. The wire is inbetween the layers of the rubber, the wire is used on the suction side of the pump to keep the hose from collapsing at high rpm.
