  New Posts New Posts RSS Feed - OJ prop shaft seals ?
kevman38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevman38 Quote  Post ReplyReply Direct Link To This Post Topic: OJ prop shaft seals ?
    Posted: July-19-2007 at 1:58pm
Is anyone using OJ shaft seals. There is some info about the pss ,but not very much on the OJ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 2:31pm
They are both pretty much the same but I would simply install the good teflon Gore-tex packing and be done with it. It's a lot cheaper.
SkiBum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiBum Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 7:29pm
Just converted to the OJ. Is was an easy install. Works very well. Just as good as the PSS I would suppose and a bit cheaper.
Bill
bchesley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bchesley Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 1:03am
I talked to the guys at skidim about both systems and they recommended the PSS for an older boat with an original shaft. They claim that the OJ seals will wear our fast on a shaft that has had a packing system run on it for any length of time. If you ave a new shaft there is nothing to worry about. It makes since so I bought the PSS and will be installing it in a week or two. I will post results.
Brad
2001 SAN
"Python Powered"
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 1:12am
Pete, is the gortex pretty maintenance-free? Do you still have to allow the slow leak to lubricate the shaft?
Mullet Free since 93
95 Sport
1978 Ski Nautique
85Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 85Nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 3:53pm
this is a stupid question can someone take pics of how to put a new prop on.
Is it just put the prop on the shaft and tighten the bolt and use that to press the prop on and cotter pin
I just never have done it and now i have two new props on the way because the two i had a bent
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 4:15pm
No, thats a prescription to f it up.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 4:16pm
Thread on prop pullin and installing
This should do it but I totally disagree with the person who is greasing the taper. DO NOT GREASE. It is the taper that transmits the HP and torque from the shaft to the prop. If the taper is fit properly (you should check it) you wouldn't even need the key.
