  New Posts New Posts RSS Feed - Tightening throttle lever
curbsidegold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote curbsidegold Quote  Post ReplyReply Direct Link To This Post Topic: Tightening throttle lever
    Posted: March-21-2005 at 2:10am
My CC has the older style throttle ... a lever mounted in the center of the steering wheel. by turning clockwise I increase throttle. The system connecting it to the engine is a series of levers that work very well.
The problem is that the lever is loose. Engine vibration alone will cause the throttle to slip clockwise, inadvertatly causing the engine to throttle up. Has anyone had any experience with either tightening or providing counter force??? Thanks. SM
sm
Siveck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Siveck Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2005 at 9:31pm
Maybe some Loctite could help if there are some threads without it.
woodyelc View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodyelc Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2005 at 12:24am
what year is this model. has to be in the 60's to have throttle in the steering wheel. please let us know. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote curbsidegold Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2005 at 1:16am
I have it listed in "diaries" as a '49 Utility Junior. The pics I have posted there do not do justice as they are pre-restoration. '49 is a best guess as there was no hull card when I bought it, and the guy who sold it to me had some documentation dated 1949.
I talked to some people at Correct Craft in Florida and we matched dimensions to some pics from that time period ... but it could also be early to mid 1950's. SM
sm
nates78ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2005 at 8:35pm
First question is does a rod run from the lever at the bottom of the column to the carb or is a cable attached to the column.
Nathan
My '78 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote curbsidegold Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2005 at 2:28am
All rods, no cable
sm
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2005 at 10:24am
Since it is a rod you need to make a throttle brake.
The easiest way to do this is to make the rod fit tighter as it passes thur one of the support blocks for the rod on located on the stringer. If it has wood blocks make a new block by drilling a hole the size of the rod in the woodthen cut it in half. Put it in place on the stringer then tighten to mounting screws to create drag on the rod. The problem is that with age the holes in the original blocks get larger. If you need some more help let me know.
Nathan
My '78 Ski Nautique
