  New Posts New Posts RSS Feed - ’94 Fuse Panel
’94 Fuse Panel
OBXSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OBXSki Quote  Post ReplyReply Direct Link To This Post Topic: ’94 Fuse Panel
    Posted: August-11-2007 at 11:14pm
OK, guys, I feel like an idiot, but I've got this relatively new boat to me and have the need to locate the fuse panel. Where in the heck is it? Do you have to take part of the inst. panel off?
Thanks for the insight.
OBXski
'94 SN
'76 SN
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2007 at 12:05am
there is no fuse panel...you have breakers on the dash and you have breakers on the motor...as is on my 94.what are you looking for/to do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote OBXSki Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2007 at 12:20am
Radio / cd player quit working. None of the four breakers activate it anymore. I can't remember which one was supposed to activate it. One works the lights under the washboards. The other three are up for grabs. Thanks.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2007 at 9:23pm
what year?......on my 94 acc 1 is for the cig lighter/12v acc acc button numer 2 or 3 is for my mood lights....other 2 dont do anything...reading from my manual for ya it states accessories: if you have additional componets installed on your boat such as cig. lighter searchlight compass light depth flasher and the like, these may be controlled by these switches. before randy (in ohio) hooked mine straight to the batt, mine would come on by pressing the ignition breaker in....you might have a fried headunit, or a loose wire.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2007 at 12:38am
i just realized you have a 94 also.......should come on with the ignition button pressed in(if stock)
Post Options Post Options   Thanks (0) Thanks(0)   Quote OBXSki Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2007 at 12:42am
Thanks, Ryan. Really appreciate it. I checked it thoroughly while we were out today. The radio is probably tied to Acc 4. Acc 4 will not reset. In other words, Acc 4 will not depress and activate the light. Do you have to take off the Acc panel and look behind it to figure out what happened to the breaker?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2007 at 12:24am
there are four thumb screws that hold the entire dash on...they are silver in color, two up frontby the windshield two by the steering wheel..you now have access to eveything...if it doesnt pop in and out its proable bad...call skidim and they will get you one sent out for around 15.00-18.00..check for a loose wire first!....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2007 at 7:55am
Before you start spending money, I would get out a volt meter or test light and find out whats wrong first. It may save some time and money.
If you don't own a volt - ohm meter, I highly recommend getting one. They are handy around the house and can be purchased for about $30 with the ranges you would need. They come with basic instructions on how to use them and you do not need to have a electrical or electronics background to use it.
